Miter Saw Station
/ Miter Saw Station
Well, this is proving to be a very informative exchange isn't it!
Yes Rox, I did use a laser for the tables. I also put the legs of the support on adjustable feet for fine tuning and to accomodate any future settling etc. And I'm very much looking forward to the new freedom of my Workmate table. It is very handy but not when it's tied up with the chop saw nearly all the time. I've made a couple of tabletops for it, one heavy duty for my bench tools and one that's now covered in hundreds of layers of paint which is my painting station.
Tom, thanks for the link, I think I've seen it before. I've recently moved up from my shop vac to a "real" dust collector but have much to do yet before the MDF is a joy to work with. I do like the stuff though, as it is so stable and easy to cut. I made my countertops in the bar area out of it and they turned out very well after I added the formica.
Scott, I had considered a ceiling mounted air purifier in our old house and may reconsider that now. I'm still young enough that I'm sure I could benefit later in life.
And B8FISH, my original concepts had every bell and whistle including built in clamps and tapes. I decided to skinny the project down so I could actually get it done. I'll likely still add the stick on tapes and I think I can still route a dado to mount an aluminum track for stops/clamps. I like that system though for now I can continue to use a QuickGrip and block of wood.
Thanks again everyone for the great ideas /forums/images/graemlins/smile.gif
/ Miter Saw Station #22
Mornin Rob,
One more suggestion and I will leave you alone /forums/images/graemlins/grin.gif When cutting MDF I use my Delta Unisaw hooked to my dust collector. The key is in getting a replaceable throat plate for the saw made exclusively for the width if that blade! This greatly minimizes the amount of airborn dust generated by the saw. I made a replaceable throat plate out of 1/2" aluminum jig plate with replaceable center sections made out of lexan polycarbonate. That way I can use my dado set insert and just change it out when Im using a single blade. I know everyone does not have the resourses to do that, so you can still make it out of a hard wood or buy a plastic blank from Woodworkers Warehouse etc. Just a suggestion.
scotty
/ Miter Saw Station #23
Beautiful job !!!
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2022 EZ-GO ELITE...
