Missing Serial Number
/ Missing Serial Number
It is possible they changed the panel a few machines prior to adding the valve. Also possible the valve developed internal leakage (some history of that) and owner just removed and connected the pilot pressure hoses together for the control pattern desired. Does it look like there may have been bolts in those 2 holes adjacent to the slot? if so the valve was removed. You could also take a look behind the panel and see if the hoses to right and joystick are one piece from handle to control valve or if there are JIC connections in that area. If one no extra hose connections and/or signs of bolt on the paint then it is prior to selector valve.
I'd hate to say for certain, but I did not see any obvious signs of bolts having been in those holes. Like damaged paint, where the head, or a washer, had been. It's been a while since I had the joysticks out, where I could see the connections, but I think they are one line from stick to blocks, below the floor. So, it looks like mine is earlier than -7113.
Which leads to another question. Maybe I should start another thread for this one, but I suspect it's been mentioned, before. Does that selector valve do anything other than change the controls? I tried changing the hoses, under the floor, which put the controls the way I want them, but it caused other problems. One was, the dipper would barely move inward, unless the boom stick was also opened, slightly. I put the hoses back, and the problems went away. So, I'm thinking that valve must do more, than just switching the controls.
/ Missing Serial Number #22
No, that valve simply changes flow from both joysticks to the dipper and boom depending on control selection. 4 hoses feed into it from joysticks and 4 hoses out to the 2 control valve spools.
Do you have any idea, why switching the hoses, under the floor, caused the other issues?
I haven't been able to locate the serial number, inside the frame. Maybe, they hid it behind the hoses, instead of putting it in the relatively open area. I'll look again, later today.
/ Missing Serial Number #25
No idea why you had the Dipper arm problem other than either the end of the control spool was not getting sufficient pilot pressure to shift the spool or the fluid in the other hose at opposite end of spool was not opening to tank line at the joystick. The serial number is hand stamped into the frame at the weld station prior to paint and not is a precise location, so it could easily be hidden behind hoses and/or not easily visible under the paint depending on how hard the welder hit the stamps with the hammer.
I have been in touch with Bobcat and was told they could figure it out, if I could give them numbers off either drive motor, the right pump, or the main valve. I gave her numbers off both motors and the only number I could find on a pump. She was unable to tell me anything from them. The left motor was a replacement, so that didn't surprise me, but I'm pretty sure the right one is original. My last hope is the main valve. I have no idea what that is. Or, where to find it. Do you?
/ Missing Serial Number #27
Surprised she didn't ask for engine s/n because the machine and engine serial number are the 2 numbers recorded on the original delivery report. The other numbers are listed in the production build sheet but required more data searching than just Delivery report by engine serial number.
I gave her that, too. It's not in their system. I'm starting to think this thing was never built. You have any idea what is meant by Main Valve?
/ Missing Serial Number #29
Main valve is the stack of all control valve sections bolted together. If it has a number it will either be on a metal tag or hand stamped to one of the end caps.
I'll look for that, on Monday. Thanks for telling me what it was! I was looking at it this afternoon and noticed a round thing with more hoses than I could count, coming out of it. At least seven or eight. It's on the right side, near the house rotating motor. Any idea what that is?
/ Missing Serial Number #31
That the swivel joint. It makes the rotating connection of all the hoses that control valves down to the undercarriage to travel motors, blade cylinders, case drain lines, etc.
Just a quick update. I have pressure washed as much of the frame as I can get to, and looked everywhere I can stick my head. Still no luck. It's looking like I'll just have to pick a number, within the range you gave me, and hope for the best. Thanks again for everyone's input, especially SSdoxie.
SSdoxie, I may have stumbled onto the answer to one of my previous questions. I found one of your messages from several years ago, where you explained how to switch the controls. What you described, is not the hoses I switched. I believe I got the ones next to the right drive (boom, I think), but when I traced the dipper hoses, they went to another block, under my left foot. In the photo, it's the one with white tape around it. It might be easier to spot the green markings on it. Could that be what caused the other issues I mentioned in a previous post, even though it did switch the controls, as I wanted? Now, if I can remember how to post a photo. Top of photo is toward front of machine.
/ Missing Serial Number #34
Sorry I haven't been here for awhile. It has been too many years and far too many design changes for me to remember which functions were in which control valves. Olst access to all online schematics when retired.
I don't know if this will help your memory, but here is one of the drawings I've been looking at:
(Wow! I didn't think the address would be that long. If you can't find the page, I'll describe how to get to it.)
It's in the shop now, to have the differing track speeds and the coasting cab, fixed. I hope.
If someone can tell me why the address I pasted didn't show up, I'll try to do better, next time. Let's try it this way. Go to Bobcatpartsonline.com. Click on Model number, above the search box. Enter 331 into the search box. Click the search button. Click on 512913001 & above. Click on Hydraulic system. Scroll down to Hydraulic Circuitry (RH Joystick controls) (Bucket & Arm) (Standard Control Pattern) (Serial Number 512915200 - 512917112, 516711001 - 516711270).
I can't say there is every drawing you could ever need, but, there are a lot. Anyone with a 331 (or X331) might want to save this one.
/ Missing Serial Number #37
Long URLs have always posted for me, will try yours from my computer:
/ Missing Serial Number #38
Well it shows before posting as seen in the snip:
But not in my post above?
Same thing happened to me. It was there, until I posted. I'm still a newbie here, so, I thought I had done something wrong.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
SET OF (3) HYDRAULIC HOOKUPS (A63569)
SET OF (3)...
2015 Ford F-150 IN-OP at time of listing (A63118)
2015 Ford F-150...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
