Missing plug?
/ Missing plug? #1
Quadder
Ma.
John Deere 410
Hey everyone...newbie owner of a 2000 Deere 410. As I was changing the oil, I notice I could see the inside of what I think is the transmission case. If the tractor is running, I can see it spinning. I'm thinking there should be a plug or something here and not open. Can anyone help? If you have a part #, that would be great.
Thanks in advance.
/ Missing plug? #2
I can't get a real good perspective of what I am looking at but I bet it is a drain hole and is not meant to be plugged.
/ Missing plug?
I don't think it's a drain hole due to it's location. I thought it was the clutch housing.
JOHN DEERE Parts Search | FREE
I'll take a better look tonight and snap some more pics. I can't imagine those internal components should in contact with dirt and grime.
/ Missing plug? #4
Maybe it's the engine flywheel timing hole????????
/ Missing plug?
I think you might be right....right next to the engine. But should it be exposed?
/ Missing plug?
So it's definitely that part I linked to above. The inside part that spins when the tractor is running has the #3 on it. I'm thinking a cap similar to 15 on that parts list might be the one though I cannot see on the other side of the housing in that pic....hmmm
/ Missing plug? #7
So is it the hole that relates to #15 or #14
/ Missing plug?
The hole I'm talking about is on the other side of the case and isn't even shown in the diagram. I took the plug out of 15 and it fits perfect so I may just order one of those. Plug #15 is for the flywheel. Anyone know what the hole on the other side is for?
Striker Slide in Spreader Box (A62679)
Striker Slide in...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2011 CLARK OIL FIELD FLOAT (A65643)
2011 CLARK OIL...
Hutchinson Grain Auger (A64127)
Hutchinson Grain...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
