Missing Accessory from Power-Trac Product Line
   / Missing Accessory from Power-Trac Product Line #1
Rara Avis
VT, ND & OH
John Deere
Is there any accessory that PT doesn't make, but should?
If you need ideas...check these options...;)
   / Missing Accessory from Power-Trac Product Line #2
This would be great if you had to vacuum leaves off the road:
Unfortunately, it looks like it would be a pain to actually use it anywhere you had to turn a corner or maneuver around a tree. LOOK! There goes the leaf train!
Jackhammer and vibrating plate would be great.
   / Missing Accessory from Power-Trac Product Line #3
Just some thoughts from looking at similar, more expensive machines.
Perhaps a front-tipping bucket to make up for the limited lift height:
A land plane or leveller -- though the slotted bottom of the new grapple may work, or they'd be easy to build:
A true rock or root bucket, perhaps with a grapple:
Like this:
   / Missing Accessory from Power-Trac Product Line #4
It works.
   / Missing Accessory from Power-Trac Product Line #7
That's a 21 degree slope limit, with a rigid articulation.
Lots of cool attachments though, including a telescoping arm.
JD-Beach said:
wow, check out the video on the lower left corner of this page.
Technical data
   / Missing Accessory from Power-Trac Product Line #8
I was looking at the specs of the 600 It says it can lift 1400 K but tips at 1100K... Hmmm.....
   / Missing Accessory from Power-Trac Product Line #9
I think it is saying that the hydraulic lift power is sufficient to lift 1400 KG but that the tipping load is 1100 KG.
In the US the rated load for skid steers and other equipment is 1/3 or 1/2 the tipping load--depending on the specific standard that applies. However, as has been discussed elsewhere, it appears that Power Trac does not compute the lifting capacities using generally applied standards--rather PT lists a rating more like that for the machines listed in the Technical Data link--either hydraulic lifting capacity or tipping load.
   / Missing Accessory from Power-Trac Product Line #10
So, this is what confuses me. The GEHL says it can lift 1400 KG but is going to tip over at 1100 KG. So, hey, even though you are nose down in a ditch you can still lift 1400KG? I am so confused...
New/Unused 2025 CFG H15R Mini Excavator (A48837)
New/Unused 2025...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
4-Compartment Metal Storage Box (A49346)
4-Compartment...
2013 Chevy Silverado 2500 HD (A50397)
2013 Chevy...
2005 JOHN DEERE 120C EXCAVATOR (A50458)
2005 JOHN DEERE...
2021 Case Trident 5550 Spreader (A50397)
2021 Case Trident...
