Minimum Shed
/ Minimum Shed #1
JD32031980
Estes Park, CO
John Deere 3203
I need some advice on minimum outside tractor storage suggestions. Enough to adequately protect a 3203 mountains of Colorado.
/ Minimum Shed #2
Try 4' around the tractor add more if attachment.
/ Minimum Shed #3
Minimum for me would be a tarp over the tractor, tied to concrete blocks to hold the tarp in place.
/ Minimum Shed #5
50'x100'
You realize no matter how big you build it you will eventually wish you went bigger.
/ Minimum Shed #6
There are guys on TBN that use containers. They are probably 7' inside width? If your tractor would fit in one it would make excellent storage. No worries about snow load. :)
/ Minimum Shed #7
I'd say a tarp would be the minimum as mentioned above. If using a tarp, use one that doesn't reach the ground so it allows air flow. After that I would say a metal carport. Then a container, small shed, pole barn, etc etc.
/ Minimum Shed #8
A trap will be cheap and you get what you pay for. Might last a year...maybe less. You will have many hours of pleasure putting it on and taking it off.
A double size carport is less than $2000 installed. Down the road, you can add walls, doors etc if you desire.
/ Minimum Shed #9
As for the absolutely smallest to house your tractor (and I contend that you'd be foolish to make it this small) is 2' on each side for access, 2' at the front and 4' at the rear. If you have an implement attached when it's put in the shed, I'd add the length of the implement plus 2' more. So width of tractor (or widest implement) + 4', and length of tractor + 6', or length of tractor and implement + 8'.
Note: This does not give you much room, about all you'll be able to do is check oil, etc and get on & off.
/ Minimum Shed #10
This cost me $800 in materials. 12x12.. You can do something similar and it be free standing if you put some posts in the ground if you don't have an existing structure to come off of..
/ Minimum Shed #11
We installed a metal building large enough so we could drive our tractor underneath without having to put the ROPS down each time.
/ Minimum Shed #12
Atsah, what did you put on the ground in your shed? Looks effective.
/ Minimum Shed #13
I dug it down three feet, removed all the clay, put a foot of one inch gravel and then foundation foam and then filled it with 1/2 inch gravel and compacted it. On top of that and directly under the tractor I laid out rolled roofing..
It's the only piece of ground that never is effected by frost of my property, and no rust on any equipment I put in there..
/ Minimum Shed #14
Very nice! Gives me some good ideas. Thanks for sharing!
/ Minimum Shed #15
You wouldn't need to go as extreme as I did if you are doing it in TX, our problem in ME is four feet of frost on anything uncovered, so I figured three feet was perfect covered..
/ Minimum Shed #16
That's a nice shed! How did you attach to the existing building? I want to do something like this off of my shipping container.
/ Minimum Shed #17
I ran a 4x6 the length of the existing shed (a 2x6 would be plenty) and ran the 2x6's for the roof off of it, I installed angle iron brackets from each 2x6 to the 4x6. 2x6's 16 on center, I used strapping to screw the metal roofing to..
If I did it again I would use 1/2inch plywood, it would have been easier to screw down the roofing and would have cut the rain noise, if it's raining hard it's really loud under there..
/ Minimum Shed #18
I built a 12'X20' lean to attached to an existing shed, cost me $500ish in materials since I found the metal roofing used for $50... Here's a construction picture, attached to the original shed by lag bolting a 2x6 to the studs.
/ Minimum Shed #19
Basically what I did.. Cheap and effective...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2019 Deere 35G (A64126)
2019 Deere 35G...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
Bobcat Mini Grapple (A64126)
Bobcat Mini...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
