Mini-hoe usefullness
/ Mini-hoe usefullness
How many hours did it take you to dig that? It looks like quite a bit of dirt was moved. Is that a home made minihoe as it looks different than the power trac built one and will it handle a 16 inch bucket without too much trouble. Quite impressive.
/ Mini-hoe usefullness #25
I am impressed that you could do that in one weekend with a PT180.
Bob Rip
/ Mini-hoe usefullness #26
I had a total of 16 hours digging time. Its hard to see from the pictures, but when I built the first wall I installed 1/2" rebar tie backs to every second post. The rebar was set at a depth of 2', so I had to use the mini hoe to dig down below the rebar the entire 70'. Then I had to dig out a 20' tree trunk I had buried when I backfilled the orig. wall. Once I got that out of the way I used my LMB and started from the edge of the road and worked my way in taking out each rebar as I went along.
I had a local welder fabricate the mini hoe to my design and specs. last year. I purchased the 9" & 16" buckets from a company in Canada. I also installed bolt on teeth on both buckets, and it really increased the digging power. I used the 16" bucket for most of the digging with no problems at all.
vERY IMPRESSIVE . I think I like the design of your minihoe better than the one power trac sells. How much do you figure you have invested in making it and the buckets?
/ Mini-hoe usefullness #28
I figure my total investment including both buckets and the new 3 spool valve is about $1300.00. I am looking into buying a mig welder and taking a welding course, so I can start building my own attachments, Brush grapple etc. I don't think I'll save any money by building attachments myself but at least they will be built to my needs and specs,
/ Mini-hoe usefullness #29
$1300? Impressive considering the PT Mini-hoe costs $1100 with the 9" bucket. Basically you bought the new valve and two buckets for just a couple hundred more than it would of cost to buy PTs version and I like your design better. /forums/images/graemlins/grin.gif
/ Mini-hoe usefullness #30
Very nice indeed !! a little 180 on Steroids… keep the pictures coming... /forums/images/graemlins/smirk.gif
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
Atspower Mini Excavator (A60352)
Atspower Mini...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
1143 (A63745)
1143 (A63745)
John Deere 5045E for sale
John Deere 5045E...
