Mini Hoe Project
   / Mini Hoe Project #21
If the rubber cups that you have are like the ones that pt has for the smaller hoses , I got two from pt to go on mine. they are a tight fit, but I managed to wrestle them on my hoses.
   / Mini Hoe Project #22
I got one set that pt has but I tried 1 inch rubber chair tips to cap over mine, They fit snug, but are still easy to get off. I drilled a hole in the end of the tip and put a small eye bolt through the hole with a washer on both sides and tightened up the nut , tied a peice of mason string in the eye hook and tied the other end to the hose, works good. Does any body know where you can get a boxed end open end wrench to fit the nut on the center section bottom bolt? They said that it was a 1 13/16 inch wrench but so far I haven't been able to find one. They told me at pt to check it after I had used the machine for a while to make sure it stayed tight. If it is loose and allowed to shift back and forwards any length of time it will egg shape the joint and cause it to break.
   / Mini Hoe Project #23
<font color="green"> They said that it was a 1 13/16 inch wrench but so far I haven't been able to find one. </font>
Here ya go, $104.98 will get you a nice German Heyco combination wrench to use once and hang on the wall. /forums/images/graemlins/tongue.gif
This is the first mention I've seen of the center section nuts loosening. Maybe we all need a big wrench hanging on the wall. /forums/images/graemlins/tongue.gif
I have a huge 2 foot monkey wrench I thought I was crazy paying $5.00 at a flea market for that has since saved many a day.
I only wish it was left handed,
Sedgewood
   / Mini Hoe Project #24
<font color="blue">Here ya go, $104.98 will get you a nice German Heyco combination wrench to use once and hang on the wall.</font>
LOL!!! /forums/images/graemlins/laugh.gif
Do you have any of these?
Board stretcher
Left handed monkey wrench
500' of flight line
5 gallons of prop wash /forums/images/graemlins/grin.gif
   / Mini Hoe Project #25
<font color="green">Do you have any of these?
Board stretcher </font>
Naw, I don't need no steenkin' board stretcher; I do it the old fashioned way.:D
Sedgewood
   / Mini Hoe Project #26
104 dollars for a knuckle buster lol. I live 18 miles from a chinese importer and 15 dollars gets a giant knuckle buster but they tend to do good. I call mine a cresent hammer. Dual usage lol. Im making a set of 2 to 3 inch sockets on my pattern burner. Ill take them to a full machine shop and Die file them and then heat treat. Ill pres s them into a pipe and make some deep wells. One thing we are required to do pn the bolts on certan crane parts is when they are torqued we take a chisel and put a fileable burr on them to keep the nuts on. Last thing you want is a 900 pound sheave wheel earth bound.
David Im almost done with the micro hoe gotta get some more pattern wire to make the compound bucket linkage and make a small die for the punch press to make the starting bend in the bucket. Take care Taylor Lambert
   / Mini Hoe Project #27
<font color="red">I call mine a cresent hammer.</font>
Not quite as good as a Stillson hammer, but better than a Phillips hammer
   / Mini Hoe Project #28
On a side note: Have you posted any pictures of your pattern burner in operation? I can't recall.
   / Mini Hoe Project
Yes, got two from PT when I was out there. Very tight fit, was easier to take fitting off the hose and slide on which I have done.
Have you looked into a good location to mount a small tool box?
PJ
   / Mini Hoe Project #30
Toy:
I was told by power trac several years ago when I got my 422 that the wrench to buy was a 1 7/8" and thats what I got and have used. Harbor freight and Northern tool have the jumbo sets and they will sell separately., I found mine locally.
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
