Mini Hoe Project
/ Mini Hoe Project #21
If the rubber cups that you have are like the ones that pt has for the smaller hoses , I got two from pt to go on mine. they are a tight fit, but I managed to wrestle them on my hoses.
/ Mini Hoe Project #22
I got one set that pt has but I tried 1 inch rubber chair tips to cap over mine, They fit snug, but are still easy to get off. I drilled a hole in the end of the tip and put a small eye bolt through the hole with a washer on both sides and tightened up the nut , tied a peice of mason string in the eye hook and tied the other end to the hose, works good. Does any body know where you can get a boxed end open end wrench to fit the nut on the center section bottom bolt? They said that it was a 1 13/16 inch wrench but so far I haven't been able to find one. They told me at pt to check it after I had used the machine for a while to make sure it stayed tight. If it is loose and allowed to shift back and forwards any length of time it will egg shape the joint and cause it to break.
/ Mini Hoe Project #23
<font color="green"> They said that it was a 1 13/16 inch wrench but so far I haven't been able to find one. </font>
Here ya go, $104.98 will get you a nice German Heyco combination wrench to use once and hang on the wall. /forums/images/graemlins/tongue.gif
This is the first mention I've seen of the center section nuts loosening. Maybe we all need a big wrench hanging on the wall. /forums/images/graemlins/tongue.gif
I have a huge 2 foot monkey wrench I thought I was crazy paying $5.00 at a flea market for that has since saved many a day.
I only wish it was left handed,
Sedgewood
/ Mini Hoe Project #24
<font color="blue">Here ya go, $104.98 will get you a nice German Heyco combination wrench to use once and hang on the wall.</font>
LOL!!! /forums/images/graemlins/laugh.gif
Do you have any of these?
Board stretcher
Left handed monkey wrench
500' of flight line
5 gallons of prop wash /forums/images/graemlins/grin.gif
/ Mini Hoe Project #25
<font color="green">Do you have any of these?
Board stretcher </font>
Naw, I don't need no steenkin' board stretcher; I do it the old fashioned way.:D
Sedgewood
/ Mini Hoe Project #26
104 dollars for a knuckle buster lol. I live 18 miles from a chinese importer and 15 dollars gets a giant knuckle buster but they tend to do good. I call mine a cresent hammer. Dual usage lol. Im making a set of 2 to 3 inch sockets on my pattern burner. Ill take them to a full machine shop and Die file them and then heat treat. Ill pres s them into a pipe and make some deep wells. One thing we are required to do pn the bolts on certan crane parts is when they are torqued we take a chisel and put a fileable burr on them to keep the nuts on. Last thing you want is a 900 pound sheave wheel earth bound.
David Im almost done with the micro hoe gotta get some more pattern wire to make the compound bucket linkage and make a small die for the punch press to make the starting bend in the bucket. Take care Taylor Lambert
/ Mini Hoe Project #27
<font color="red">I call mine a cresent hammer.</font>
Not quite as good as a Stillson hammer, but better than a Phillips hammer
/ Mini Hoe Project #28
On a side note: Have you posted any pictures of your pattern burner in operation? I can't recall.
/ Mini Hoe Project
Yes, got two from PT when I was out there. Very tight fit, was easier to take fitting off the hose and slide on which I have done.
Have you looked into a good location to mount a small tool box?
PJ
/ Mini Hoe Project #30
Toy:
I was told by power trac several years ago when I got my 422 that the wrench to buy was a 1 7/8" and thats what I got and have used. Harbor freight and Northern tool have the jumbo sets and they will sell separately., I found mine locally.
/ Mini Hoe Project #31
David I had posted some a month or two ago in the Photo's section called my winter work. Im burning a 2 inch plate out. I burnt a 13 inch circle out of one to make a bearing eat and then I cut a wedge off one corner to go into a frame straightener.Its quirky to use some times as the patterns ahve to be 1/8 th of an inch smaller on each side or larger dependin on inside and out side cuts. I make wire patterns and the tracer wheel follows it. I cut some 4 inch a few weeks ago. I also use it to cut alternator slide brackets and such.
/ Mini Hoe Project #32
Heres that Pattern torch. Its an older Linde unit but still works good. Its gt a 10 inch thick capaicty and a 40 inch linear travel.
/ Mini Hoe Project #33
These pics show it cutting the 2 inch plates, remeber dont look at the ugly mug running it lol.
/ Mini Hoe Project #35
David look under the right lower corner of the control box. It has 2 arms sticking out to hold a pattern. for the wedge it was an angle iron straight edge. Look on the machines Cast iron table and youll see the pattern to the circle I cut out. I usually use 1/4 and 5/16ths wire for my patterns. ive got a few rolls of film here with a set of better views of the machines mechanisms. Its just one toy in an out of control hobby.
/ Mini Hoe Project #36
<font color="blue"> Its just one toy in an out of control hobby. </font>
Ha! You got that right. /forums/images/graemlins/laugh.gif
Thanks for the explanation.
/ Mini Hoe Project #38
It really is. I do alot of things that require to or three things made like bucket fork hooks, buckets sides backhoe thumbs and grapples. It took 5 hours to layout with a template freehand cut and die grind a set of three bucket fork hooks and the end caps now it takes 35 minutes to put a plate in and cut a set out. the thickest ive cut is 5 inches. Half the capacity. Im building one similar that has a stationary torch with a otating workpiece for cutting out roller drum caps.
If I can find the manual Ill scan some of the pics.
/ Mini Hoe Project #39
I have been kind of thinking of making an enclosure for mine for the winter, one that I can take off and put on easily. I have got an idea how to make one, but I have been so busy that I haven't got to work on it yet. If I can get that to work then I intend to put a small tray on it to hold some small stuff . I have a light bar on mine with lights to see to back up with if I am working at night and a set of red lights if I have to tram on the road to make it easier for moterists to see it , might save me from getting hit.
/ Mini Hoe Project
Understand the busy part. When things slow down would like to see a picture of your light bar and how you wired it.
PJ
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
LOT OF 2" SQUARE TUBING (A64278)
LOT OF 2" SQUARE...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
3144 (A63117)
3144 (A63117)
