Mini-Fuse Wire Tap
/ Mini-Fuse Wire Tap #1
MikeyB
Parker,CO
JD 3320
I am wiring some rops lights on my JD 3320. I am planning on using a "mini fuse tap-off" circuit I bought at an auto parts store and tapping into my worklight circuit. This circuit plugs into the mini fuse block and then has a second fuse for the new circuit This allows me to power the lights using my headlight switch but I will also be adding an inline switch so I can turn the rops lights off at will. Any thoughts until I get in too deep? I have the prelim wiring done but haven't tapped the power portion yet.
Thanks,
Mike
/ Mini-Fuse Wire Tap #2
The only caution I would have is how many amps you are going to pull through the factory switch. How many lights are you adding?
I am adding two 35w lights so 6 amps or so draw. The circuit for the additional lights will be tapped off the worklight circuit and not the headlights.
Mike
/ Mini-Fuse Wire Tap #4
Sounds like a plan! Be sure to post some pics!
/ Mini-Fuse Wire Tap #5
I did this same thing with my old kubota only i used a relay and a seperaste power source from the battery. this way you do not overload the switch or circuit. The circuit you are taping into was designed to carry a specific load, you change that load/resistance you might start cooking a switch or a circuit. does your factory switch apply power or ground to the lights? a simple realy should do the trick and save you from any problems down the road.
/ Mini-Fuse Wire Tap #6
Almost ALL circuits remained grounded, and power is applied. that's pretty standard electrical principle for wireing. You don't often switch grounds, except in very specific circumstances.
Soundguy
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2150 (A65055)
2150 (A65055)
1996 Aspen FP601 Single Pump T/A Acid Pumper Trailer (A64194)
1996 Aspen FP601...
(INOP) GRASSHOPPER FRONT DECK MOWER (A64278)
(INOP) GRASSHOPPER...
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A64556)
2014 Hyundai...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
