Mini Excavator Skid Steer adapter
   / Mini Excavator Skid Steer adapter #1
Walter63
Has anyone on this forum had experience with an adapter that allows the use of skid steer implements on a KX71-3 mini excavator or similar ?
   / Mini Excavator Skid Steer adapter #2
I got one to do a specific outside barn repair using pallet forks and man basket. Used on M59 that has the KX excavator QD on the backhoe. Could not reach with the FEL. Also allowed me reach inside barn too. Yes it took two people. My wife at the controls. But much safer and quicker than building scaffolding.
Future plans using an auger and Danuser Intimdator.
   / Mini Excavator Skid Steer adapter #3
Walter63,
Have a look at USA Attachments. That is where I purchased my M59 to KX series quick attach coupler, giving me access to the KX tool line ( new and used) which is far more extensive and less expensive than the M59/M62 specific quick coupler and bucket only choices. I have found them to be good people to work with.
I've purchased a number of buckets with and without teeth. Also a root ripper which is not available from Kubota as either pin or quick attach.
It should be fairly easy to weld a set of KX coupler ears to a SSQA attachment plate and off you go to the races.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61307)
PENDING SELLER...
TEST YOUR BID BUTTON! (A60430)
TEST YOUR BID...
2018 Deere 323E (A53317)
2018 Deere 323E...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
