Mini Excavator Skid Steer adapter
/ Mini Excavator Skid Steer adapter #1
Walter63
Has anyone on this forum had experience with an adapter that allows the use of skid steer implements on a KX71-3 mini excavator or similar ?
/ Mini Excavator Skid Steer adapter #2
I got one to do a specific outside barn repair using pallet forks and man basket. Used on M59 that has the KX excavator QD on the backhoe. Could not reach with the FEL. Also allowed me reach inside barn too. Yes it took two people. My wife at the controls. But much safer and quicker than building scaffolding.
Future plans using an auger and Danuser Intimdator.
/ Mini Excavator Skid Steer adapter #3
Walter63,
Have a look at USA Attachments. That is where I purchased my M59 to KX series quick attach coupler, giving me access to the KX tool line ( new and used) which is far more extensive and less expensive than the M59/M62 specific quick coupler and bucket only choices. I have found them to be good people to work with.
I've purchased a number of buckets with and without teeth. Also a root ripper which is not available from Kubota as either pin or quick attach.
It should be fairly easy to weld a set of KX coupler ears to a SSQA attachment plate and off you go to the races.
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
