Min tractor size for repairing long gravel driveway with potholes?
   / Min tractor size for repairing long gravel driveway with potholes? #121
Just to be clear, I could do the things you listed with a scut as could any experienced tractor operator on this forum. It just would not be my tool of choice.
   / Min tractor size for repairing long gravel driveway with potholes? #122
A forum that tells a member what they want to hear shouldn't be too hard to find. There are also Bigfoot and ghost hunting web sites.
BX owners have reported several times, if not to tout their subs for pulling a box blade. My small CUT is quite similar to a Mahindra Max 26. Same bare wt, width, wheelbase, tire sizes (23-8.5x12 frt, 12x16.5 rr), and hp. It has position control and no med range. All work is done in low range at 4mph or so. (ugh) It pulls my drag, blade, & LR ok but takes forever to run 550 ft down my d'way in low.
btw, my >30hp CUTs can barely pull my 5' box blade so I only use it for ballast and to pull snow away from buildings anymore. All three CUTs I own spin all four tires too often with it to use the BB for much else.
   / Min tractor size for repairing long gravel driveway with potholes? #123
The OP must have obtained the necessary information after 121 TBN posts.
Time for him to just go buy a tractor, and see how it works out for him.
   / Min tractor size for repairing long gravel driveway with potholes? #124
But should we also explain that a rear blade is much better than a box blade for driveway maintenance? :unsure:
   / Min tractor size for repairing long gravel driveway with potholes? #125
Just about everyone said go buy a SCUT if you are laser focused on that ... It just isn't the best choice for the tasks identified.
Heck, I'd like to have a SCUT to add to my stable. It would just see limited action.
   / Min tractor size for repairing long gravel driveway with potholes? #126
A land plane is superior to a box blade for a driveway. Scut ain't gonna do it. Check out GP Outdoors, he does a fairly in depth evaluation.
   / Min tractor size for repairing long gravel driveway with potholes? #127
Of course!....That is obvious,...... but do you really think the OP would accept such an explaination?:)
   / Min tractor size for repairing long gravel driveway with potholes? #128
And come back within a year professing “it’s too small, I need 50HP” 🙃
   / Min tractor size for repairing long gravel driveway with potholes? #129
It obviously is,...... but do you really think the OP would accept that sort of information?:)
Some men learn by reading
Some men learn by watching
Some men only learn by peeing on the electric fence.
   / Min tractor size for repairing long gravel driveway with potholes? #130
Been there done that on the electric fence! :ROFLMAO:
ASSET DESCRIPTIONS & CONDITION (A56138)
ASSET DESCRIPTIONS...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
70pc 12ft.x 3ft. Grey Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
