Millermatic 211 vs Hobart 210MVP
   / Millermatic 211 vs Hobart 210MVP #11
Add me to the list of not liking to change wire sizes.
Was it Confucius who once said “ It is a wise man who changes socks and underwear more often than his welding wire!”?
.023 solid wire top
.035 solid wire bottom
.045 Inner Core (dualshield)
.052 fluxcore
   / Millermatic 211 vs Hobart 210MVP #12
Not everyone needs Tig. I seldom use the 5 tig welders I have. ( 2=AC/DC ) But it's nice to have one for critical welds that you don't want blobbed up with wire. I mig most of the time and only have 3 of those. It just happens that way over time. Any welder (s) you can get are good but the old saying goes, He who dies with the most welders, Loses. You could have used the capital on your 4th or 5th tractor.
   / Millermatic 211 vs Hobart 210MVP #13
I knew there was reason I am on this forum. LOL I think Confucius was a real welder.
   / Millermatic 211 vs Hobart 210MVP #14
Don't use the tig much, but for aluminum it's basically the only option. Did tig my shooting rest for the control available. One guy at the range looked and noticed, said "you got a tig, eh?" Gave me that warm fuzzy feeling. It's about the control.
   / Millermatic 211 vs Hobart 210MVP #15
i think confucius and wise ole injun were both great welders in my neck of the woods both had shops
   / Millermatic 211 vs Hobart 210MVP #16
What type of welding machines? 110v? 220? INJUN drive?
I suspect that I wouldn't change wire size very often. Unlikely to weld much on sheet metal or thinner gauges. Both of the originally mentioned welders seem to do .024, .030 and .035 without any more than the feed wheel adjustment.
TIG is probably quite unlikely for me. But who knows once I get better at welding with a MIG. There's a ton of stuff I never consider doing with my stick welder because it is just too 'coarse' for smaller parts and thinner material. That and my problems striking an arc reliably with it.
Rob
   / Millermatic 211 vs Hobart 210MVP #18
Rob I don’t recall if you mentioned having an auto dark helmet or not. I sure wish I had one when I started welding long ago.
   / Millermatic 211 vs Hobart 210MVP #19
I would go with the Hobart. It will do just fine for your needs for many years to come. If a multi process is in the cards and you aren’t brand loyal the Lincoln 210 MP has been around for several years and has a good reputation. You might even find a used one kicking around.
   / Millermatic 211 vs Hobart 210MVP #20
If money is tight I would take the Hobart.
The Miller would have QUICKER resale attributes but you would recoup a better financial percentage with the $500 cheaper Hobart if and when the time comes to upgrade or liquidate.
Of course ideally you could test drive both under similar conditions to help you decide.
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2011 INTERNATIONAL PROSTAR (A55745)
2011 INTERNATIONAL...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2012 KENWORTH T660 ROAD TRACTOR (A52706)
2012 KENWORTH T660...
Swict 72" Bucket (A53316)
Swict 72" Bucket...
