Miller PTO stump grinders vs Baumalight
/ Miller PTO stump grinders vs Baumalight #1
Woodchuckle
Eau Claire, WI
Allis Chalmers D17
I'm trying to deside between a Baumalight 3P34 stump grinder and a Miller Pro75T stump grinder. Any input would be helpful.
/ Miller PTO stump grinders vs Baumalight #2
I don't have any experience with those, but to Add to your searches, I have a Shaver SC-50 PTO stumpgrinder that I'm very happy with. In fact I used it for my first paying job a couple days ago. Mine is rated for 35-100PTO Hp. They also have a smaller model (the SC-25) which is rated up to 50HP.
What size tractor will you be putting it on?
I have an Allis Chalmers D17 55hp tractor.
/ Miller PTO stump grinders vs Baumalight #4
The Baumalight has a bigger cutting wheel, more teeth and is generally stouter.
/ Miller PTO stump grinders vs Baumalight #5
By "Stouter" do you mean more simple?
It's certainly not more stout, tough, and lacks many features. The miller main beam and cutter head, structurally, are welded boxes made of flame cut 1/2" steel plate, like an excavator dipper stick.... The Baumlight has the cutter head supported out in space on a peice of square tubing, certainly not 1/2" wall, not very robust, or stout.
And since the cutter head is just on the end of a "stick" you have no telescopic extension. That means you will need to raise the stabilizers and back the tractor up ~10X for every stump. Very frustrating, slow and inefficient....
More teeth = small chips?, costly to replace?, you only have so much horsepower in the tractor, more teeth doesn't mean much.
On that note, bigger wheel doesn't mean much either: Bigger wheel means more torque required to turn, which means slower wheel speed - since you only have so much tractor to work with.
