Miller 211, first use...
/ Miller 211, first use... #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
My next door neighbor recently got a Miller 211 and I was over there tonight to put a couple of seat brackets back on the B7500.
We were welding ~1/8" to the sheet metal on the fenders. It originally had 2 spot welds on each side, but they broke at some point and some welded it back together. They didnt have good penetration on either side and they didn't fix the root cause of the problem (the hole for the middle bolt that connects to the transmission was broken).
We removed the old welds (a cold chisel and a couple of taps with a hammer took care of that), ground them smooth, ground off the paint where we were going to weld the brackets to and re-welded the brackets. They now have ~1" of weld up each side, a weld across the top and 1-2 plug welds on the back (where the original spot welds had ripped the metal apart).
He had it on auto-set mode with 75/25 gas, .030 solid wire on 120V and it worked well. Seemed almost like the feed was always a little slow though, but that might have just been me.
Aaron Z
/ Miller 211, first use... #2
I have a 211, and it welds a little hot. If I have it on AS or on tap settings I just turn it back one setting thats on 120v or 220v. I p/u this 211 back 2009 from Air gas, I also p/u a MM252 this past Feb.2013. The 252 sits a lot the little 211 is my go to welder..
Sellick S80 (A60462)
2019 HYUNDAI V12530152-AJS DRY VAN (A59912)
2019 HYUNDAI...
2012 Dodge Grand Caravan Van (A61574)
2012 Dodge Grand...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
