BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 3,656
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
A friend asked if I could repair his mower deck, it had rusted and one of the idler pulley mounts tore loose. I said I'd give it a try. Didn't look too bad, someone had attempted to fix it a couple of years ago, and that repair had failed because of more of the area had rusted out. I cut out enough metal to get decent metal to weld a patch panel to, though it was still pretty thin in a few spots. Made a patch out of 11 ga. plate and spent some time getting it trimmed and the front side rolled up to make a better surface to weld to. I used my Miller 211 and got it tacked into place then welded it in place. I'm not a great welder, but the thin metal was a real challenge. I also had to do some cutting and grinding on the pulley mount to get it to lay parallel with the other pulleys, but I got it pretty close. Welded up some other cracks and loose deflectors, so it should be good to go for a while.
I used the BX to get it off the bench and set it outside.
