Milky Hydraulic Fluid!!
   / Milky Hydraulic Fluid!! #11
90-91% is easy to find at drug stores.
70% will work.. but will carry less water as it is already carrying water.
the 95% would be fine.
I don't have a store near me that sells it. 90-91 is the best i can find locally.. so it's what I usually reccomend.
the atf-alcohol-diesel is a darn good rinse for wet sumps.. been using it years...
   / Milky Hydraulic Fluid!! #12
Just a tip Fishman
A few years ago, I had a client that had reoccurring milky hyd and he kept changing with new oil to no avail
He ended up having a clogged suction filter/strainer which put an extra strain/vacuum on his shaft seal on the main hyd pump......the result was air entrainment (foamy oil)
the way we found it was we put a good sized sample of the milky oil in a clear jar and all the air separated on it's own in a few days crystal clear....if it had been water it would have water in the bottom of the jar
The fix was new suction filter, reseal the hyd pump and all is well
Not saying your problem is air entrainment but something to watch for on these Japanese Fords
Thanks I will check for air. I'm waiting until it warms up a bit before I work on it again.
   / Milky Hydraulic Fluid!! #14
Also check the breather on the hyd reservoir. If it's plugged the moisture has no place to escape when oil & water gets up to operating temp.
Ok Tx Jim, I wonder where that is located?? I will see if I can find that..
   / Milky Hydraulic Fluid!! #16
Tx Jim,
Can you send me this Attachment to my email so I can make it larger?? Its so small I cannot read it..
Please send it to.
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A55218)
2022 MAXXD BD14...
70pc 8ft.x 3ft. Grey Metal Roof Panels (A55758)
70pc 8ft.x 3ft...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD72...
202146 (A54756)
202146 (A54756)
