mile marker winch
/ mile marker winch #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
I was thinking about mounting a hydaulic winch on my tractor hooked in to the the FEL outlets in the front. Looking at the website it states that they operate at 1500 psi and 3.5 gpm. My system is 2500 and 11 gpm. Does anyone know if it will work reliable in this system?
/ mile marker winch #2
flow shouldnt be an issue. if anything it will just spin faster.
pressure is another story... you may blow the seals out of it. but could easly plumb a pressure reducer inline to avoid that problem.
(gpm = spool rate, pressure = pulling force)
/ mile marker winch #3
Call the company that makes them and tell them what you have and ask if it will work.
/ mile marker winch #4
I could be wrong here but, Were'nt the MM winches designed to work off of the power steering pump? If so you could adapt a boneyard PS pump to your pto and power it from there.
/ mile marker winch #5
You could even make an aux mount for a spare engine pump too. ( used ps pump is a great idea.. )
Soundguy
/ mile marker winch
Called MM and they said the units are limited to 1500 psi and 3.5 gpm and suggested installing a flow/pressure reducer in the line. Just dont know how to do that so will look at Warn that have winches good for 2500 psi and much higher flow rates. Like the idea of using the tractor hydraulics and plug into the quick disconnects in the front so I can operate the winch from the bottons on the joystick for the FEL
/ mile marker winch #7
Would it be simpler to just go electric and run it off the battery? How much pulling power do hydraulic winches have? Are the hydraulic ones cheaper?
/ mile marker winch #8
I own one electric 2000lb Warn Winch, one electric 2500lb Warn winch, one electric 12,000lb Warn winch, one electric 8000lb Ramsey winch and one hydraulic Mile Marker 10,500lb winch.
The pulling power of the winch is determined in it's construction and has nothing to do with hydraulic or electric.
Hydraulic winches and electric winches are similarly priced.
Electric winches require a high output alternator and/or dual batteries if you are going to do long, hard, repeated pulls. They develop a lot of heat and use huge amounts of amperage draw during these pulls.
Hydraulic winches require the appropriate hydraulic pressure and flow rate. They will pull all day with little heat buildup or hydraulic stress on your tractor's system.
If you are creating a system to use for long pulls and repeated pulls I would suggest hydraulic. If you are creating a system for occassional pulls of moderate or short duration, go electric.
/ mile marker winch #9
A auxiliary relief and orifice setup will get the psi and flow rate where you need it. etc..
Soundguy
/ mile marker winch #10
ovrszd
Thanks for the info. Never seen a hydraulic winch in use. For a CUT it seems like the way to go. I have a 9000 lb ramsey electric on my trailer.
/ mile marker winch #11
I have a MM winch mounted on a 3pth frame works that I made that is rated 10,500lbs. I have it on a L3830. The L3830 also is rated 2500 psi with just a little less gpm flow. It has worked flawlessly for 3 years now. I just plug it into my rear remotes. I use it for skidding logs, its 2 speed and the whole set up was much cheaper than a skidding winch.
/ mile marker winch
Just talked to Winchesplus.com technical support. They said that to operate a hydraulic Mile marker winch safely in the 2500 psi system we need use a special spool valve that they sell for 120 dollars. This spool valve is to be mounted on the winch and operated at the winch. The front hydraulic outlets on my Kubota m7040 are operated from bottons on the FEL joystick so not sure how that can work in this case. Any ideas out there?
/ mile marker winch #13
Did they say what their 'magic' spool does? If so,.. then just find something to replicate those effects.
Soundguy
/ mile marker winch #14
That is exactly who I bought my winch from and they did not say anything to me about a special valve. At what RPM does the M7040 produce 2500 PSI? That is the question that no one has asked yet. My L3830 produces 2650 PSI at 14GPM and my winch works good. Yes I said 2650 PSI because I increased mine.
Plumb into the rear remote lines and use them.
/ mile marker winch
Good question on the pressure. Pressure is related to flow on the positive displacement pump system I would think at low RPM's flow is low and pressure as well. Seems that the MM winch should be safe as long as we only rev it up to where it functions effectively. I will try it without the spool valve
/ mile marker winch #16
The pressure will be the same at all RPMs. Just the flow will change. A motor and a cylinder could use a different spool valve. A valve that is electric controled will not have any speed control. You can get a spool valve with a pressure relief valve built into it.
/ mile marker winch #17
I'd just like to remark I have a 10,500 Milemarker installed on my truck, running off the power steering pump. It is built like a tank, and will work uncomplainingly all day. I have seen electric winches start to smoke under smaller loads.
The only disadvantage compared to an electric winch is that the engine has to be running to use it.
Make sure you know the techniques for using a winch, to get maximum performance, avoid damaging the cable, and avoid lots of hassles with loose turns on the spool. Whenever possible the drum should be at right angles to the work so the cable winds evenly.
Once installed, you will love it. Let us know.
C
/ mile marker winch #18
In a recent phone conversation recently with Mile Marker he told me that if the fairlead was at least 10" away from the winch it would act almost like a level winder. In using mine for winching logs I have had to make a few redesign changes to it. One was the way that the cable is secured to the drum.
/ mile marker winch #19
Deerlope, how DID you change the drum attachment. I ripped mine off once, and had great difficulty finding someone who could swage a new anchor to the cable. I still has to be careful not to run out those last few turns of cable.
C
/ mile marker winch #20
Deerlope,
Do you have any pics of your MM winch set-up?
thanx
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2017 Ford F-250 Crew Cab Pickup Truck (A61568)
2017 Ford F-250...
John Deere 5525 (A60462)
John Deere 5525...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
