Mighty Mule gate opener
/ Mighty Mule gate opener #1
dennisoates
tawas mich
f-12
Does anyone have any experience with these gate openers? MM 2500 .I have dual gate mighty mule openers i bought used. i hoooked them up and they both move 2 inches and stop, when i hit the remote they move back 2 inches, beeps 4 times. I wire them direct to the battery and they both rapidly extentend, and retract. i have hooked them up without the slave, and they still only move 2 inches and stop. I have a 3rd am and hook it up and it moves 2 inches and stops. there are binding or obstructions in the gate as i even tried running them unhooked from the gate. the batteries test good at 13.50. I have tried called the company, but can never get thru, hope you have some good advise for me. thanks. I am not sure how to test the circuit board with the meter. thanks
/ Mighty Mule gate opener #2
are you sure about the number of beeps and also is there seconds between the series of beeps? have you tried disconnecting only one of the openers and then the other could be the counter in one of them.
i was wrong on the beeps, there are no beeps it just stop after moving 2 inches, the beeps i heard were the warning beeps
/ Mighty Mule gate opener #4
was you able to try anything else and what did you see? if neither one will work alone it may need to relearn it's open position.
no there is nothing more to see, i am told it may be the relays in the circuit board. i ordered two of them
/ Mighty Mule gate opener #6
have you tried wiping the open limit setting? make sure the gate is in the closed position and press and hold the learn mast limit for 5 seconds then try the gate if it works you'll need to stop it when it gets to the open position by pressing the remote. good luck
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
1997 International 3800 School Bus (A64194)
1997 International...
