MIG welding....push or pull
/ MIG welding....push or pull #31
Just know that if you "borrow" CO2 tanks from behind the restaurant they will be 100% CO2, NOT 25/75 (-:
/ MIG welding....push or pull #32
XXXXXXXXXXXXX
That seems to be a problem with my welder/welding. My Handler 140 is 120V and is plugged in to a 30 amp dedicated line that only runs about 3 feet from the breaker box. Using 10ga wire from breaker box to plug box. I can go with a heavier guage in about 5 minutes.
1/4" to 1/4" welds.
With welder on highest/hottest setting and wire feed on 50 +/- with .030 or .035 solid wire I cannot get the puddle to puddle like with a medium/warm 6011 stick. My welds basically look like catalpa worms. If I make quick u's then I get absolutely no penetration. If I get a little penetration I get what looks like a dirt-dobber nest. I've run both polarities without good results. Argon is turned up to as high as 50.
Any suggestions
Chain Bender
Bender, I am having problems understanding your statements. I don't know if you are using the wrong terminology or your setup is all wrong.
The 10 ga wire and 30 amp breaker is a good start.
You should practice on 1/8 to 3/16 inch stock. Too thin and you will easily burn holes and too thick you will not have the heat needed.
You say ARGON gas, I hope not. You should be using C-25, a mix of CO2 and Argon.
You should have two gas gauges on the tank, one that indicates the gas pressure in the tank [psi] and one that indicates the gas flow rate in cubic feet per hour [cu/h]. The first gas valve should be FULLY opened, the second valve on the regulator controls the rate of flow. The gas flow should be set to 15 to 20 cuf/h. too little gas and the weld is not shielded, too much gas will cause turbulence to draw air into weld arc.
With the wire feed turned to its lowest or the pressure roll open, you should hear the gas valve open and gas flow through to the gun defuser. If not correct.
Set the heat and wire speed to the recommended value for the stock. You can fine tune the arc with the wire speed control.
The wire stick out should be about 1/2 inch at an angle of 30 deg to the work.
You want to move the gun to keep the force of the arc at the leading edge of the puddle. To fast and you will not build heat for a puddle, to slow and you will over weld the weld puddle and not fuse the puddle into the base.
/ MIG welding....push or pull #33
I've tried slowing down but get even a bigger dirt dobber weld. I've turned teh ehat up and the wire feed down and just cannot get a puddle up, except on a really long weld (16") that finally at the end few inches the weld puddled out and "thinned out" like a stick weld would.
There is more than one way to skin a cat. You could try a little pre-heat with a torch. Pre-heat the weld zone for the first 1/3 rd or 1/2 of the length of the weld zone.
/ MIG welding....push or pull #34
i have always been told that a 120 volt MIG welder cannot weld 1/4" plate.....my 120 welder handbook states 1/8" max.
i do alot of 1/4" + welding, but use my stick welder (7018 with reverse dc) to get good penetration on heaver stock
/ MIG welding....push or pull #35
Might rewire from the breaker to the plug today with some 8 and maybe rewire the cord on the machine itself.
Probably won't et any chance to test it for several weeks. Having a left knee TKR Monday morning and have many things to get put up and stored before church time tomorrow.
Gentlemen, thans for all the input and free schooling. I do appreciate it and will do my best to apply as much of it as I can when I can.
If I dont reply back in a few weeks it will be becaus i cannot sit at the computer table.
much thanks,
Lee
increasing the wire size wont do a thing. its a 120 volt machine, and if the wire size or breaker were insufficient, the breaker would have tripped. Even if you installed #4 wire, the results would be the same.
I honestly feel that you need a good 240 volt MIG welder to do 1/4" plate. I see what my friends 240 welder can do to 1/4 & 3/8" plate, and theres NO WAY my 110v MIG can do that. Unfair to ask it to do something it WASN'T designed to do. By the way, I'm an electrical contractor, and while its OK to up-size the wire to an outlet, its not considered good form to up-size the breaker too much. 200% increase wouldn't hurt, but if there ever is a problem with the machine, there will be NO PROTECTION established with the breaker panel.
/ MIG welding....push or pull #36
I too am a novice welder in the middle of an intro MIG class at the local technical high school adult education program. I've had similar problems trying to weld on 1/4 inch with 110V but no problems with 220V. I wonder if the issue here is that 1/4 inch is at the limit of what a 110v welder can handle so it requires a bit more skill and experience to make it work while the 220V setup has plenty of power to overcome the lack of finesse. I know that 110 welders can manage 1/4 but it does seem to be at the outside limit of practical power despite what the manufacturers claim.
/ MIG welding....push or pull #37
You may be able to weld 1/4 inch stock but it takes lots of skill and prep work. If you cant weld 1/8 inch stock you will never weld 1/4 inch.
30 amp is the biggest breaker I would ever put on ANY 110/120 wiring I did. Pro's might do it, but I just can't do it.
Guys, I might sound confused and like a fool, but I'm not. My guages are set up correctly. Tank pressure was around 1200 psi last time I looked at it close and flow is/was around 32. Some say go to 15, some say go up above 30. I using Blue Demon ER70S-60 .030 Solid wire. Machine is running DECP and I AM using 75% Argon/25% CO2. That is exactly what the owner's manual and the diagram on the inside of the door flap recommend.
I have pretty much come to the conclusion that much over 3/16" isn't gonna work on MY table. I was thinking about pre-heating the heavy stuff like I sometimes do aluminum, but my pony bottles are empty. Probably should just stick with the stick until I get a bigger (if ever) MIG. I don't weld enough to justify the money spent on one. My wife bought me the 140 for a Christmans present about 6 or 7 years ago. I'm just trying to use it and as said above, probably asking it to do something it/I will never get it to do. I'm welding on big pieces of metal that dissapate (sp) more heat than my machine can put into it.
Got lots of last minute things to do. thanks for input
CB
/ MIG welding....push or pull #39
That's a good tip, I often let the stick out get too long, and end up with a lumpy, cold looking weld.
I think you've got lots of power to the welder, normally 20 amps on 12/2 wire is plenty for a 110v welder.
I believe you've either got a welder issue, or it's a technique problem. Either is correctable, technique being the easiest to fix.
With the edges of the work beveled, the Hobart should lay a nice smooth weld in the V on the first pass, and round it up nicely on the second or third on 1/4 stock.
I'm going to try to set up my spare hood with a video camera behind it so I can actually critique my own welding in slow time. If it turns out well, I'll post it here.
Sean
/ MIG welding....push or pull #40
I to am a novice welder. I have the same machine and can't sufficiently weld 1/4" plate. I tack it together and take it my brother's shop and use the miller 210.
Cleanliness is another key. If the metal is not prepped properly, forget it. Don't forget a solid ground. Even with 3/16", I put the ground as close to the weld as possible and do a little preheat with mapp gas. Especially if the metal has sat outside for a length of time.
Heat is on #4 with the speed on 35-40. I use .030 wire with 75/25 gas set on 20 for flow.
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
Sterling AT (A61307)
SANDBAG ATTACHMENT (A60736)
SANDBAG ATTACHMENT...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
2019 FORD F-150 XL EXT CAB TRUCK (A59823)
2019 FORD F-150 XL...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
