One of the reasons MIG gets a bad rap because everybody thinks its so easy that they don't take the time or effort to set it up correctly. MIG can achieve penetration in thick materials - with the correct size wire, current, and feed rate. How many people bother to change out the wire, rollers, and tip to switch wire sizes when switching base metal thicknesses? You are not going to get very deep into 1/2" steel with 0.025 wire, no matter how high you turn up the voltage! Those who try end up propagating the story that "MIG is for pretty ... ".
Another issue is confusing "pretty" with "strong". Just because the bead is shiny and smooth doesn't mean anything underneath was melted. Beginners can get fooled into thinking they have quickly learned MIG when in fact they have only learned how to lay down a bead, not make a weld. One thing that was told to me that has made a big difference in my weld quality by a more experienced guy was "You have to melt it to weld it". While you are welding, you should literally see the base material actually be melted or even somewhat undercut by the arc and _then_ filled in by metal from the weld puddle. The weld puddle itself isn't good at melting the base metal. The arc needs to hit the base metal, not just the puddle. This is true of all welding techniques. Just melting a bunch of wire on the surface is exactly why detracters call it the "squirt gun".
Outdoors, with any kind of wind, you have to turn up the gas flow rate. A lot. Makes MIG expensive to use outdoors, but still possible. Even indoors, many welding orientations or configurations require higher than normal gas flow. Many don't bother to turn up the gas high enough.
Gasless flux-cored wire is another good option in many circulmstances. Just load up with the gasless wire, close the gas valve, and maybe swap the polarity (as appropriate for the welding situation). The hot flux is much more agressive about cleaning and penetrating poorly-prepped surfaces. Also, the shielding action is much more resistant to wind (exactly like a stick welder). Almost all MIG machines can be used with gasless wire as well. This gives you some of the advantages of DC stick welding and the economy of purchasing only one machine.
You can also buy wire feed setups that are initially setup only for gas-less wire that you can later add the tank and regulator to so as to also have MIG capability.
- Rick
