MIG, TIG and a new helmet...
   / MIG, TIG and a new helmet... #21
Not for me, $344 for the torch and then have to buy a water cooler. Maybe if I did a lot of welding, but not for my limited use.
   / MIG, TIG and a new helmet... #22
Yeah if you can't build things for yourself it costs a lot of money.
In any case the wire feeder is the cheap and easy part. Now you need a programable welder and rotary table or robot to move it or the part, that takes a lot more doing.
   / MIG, TIG and a new helmet... #23
I could probably fab up some kind of water cooler, seen a few on Utube. Now I am trying to figure out how to make a wire feeder to go on a standard tig torch. I am pretty sure some of the stand alone wire feeder attachments for bigger welders are voltage senseing. might could use something like that, but those old Ln25's cost more than the $344 tig torch.
   / MIG, TIG and a new helmet... #24
   / MIG, TIG and a new helmet... #25
You could just use a cheap mig welder to feed wire. Just use the wire feed rollers/motor and the gun liner. Disable the transfomer and you're all set. Add a foot pedal instead of trigger switch.
2018 CATERPILLAR 303E CR EXCAVATOR (A51242)
2018 CATERPILLAR...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
ECHO SRM-2120 GAS POWERED WEED EATER (A51244)
ECHO SRM-2120 GAS...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
