Mig regulator question
   / Mig regulator question #1
amitysanimal
Carmel, ME
Kubota B7100
Any chance you can use an acetylene regulator on an Argon tank?
   / Mig regulator question #3
Calibrated differently too.
I didn't think I would be that lucky. Thank You for the replies.
   / Mig regulator question #5
If you check ebay, there are a lot of regulators there. We sell them as well. They are good units, but are in lpm, not CFH as some desire. They are a good bit less than a SMITH, of which I own one and a prestolite. They work just as good as either of those two.
   / Mig regulator question #6
Check with your local welding shop. You might get lucky.
   / Mig regulator question #8
You could probably violate all reasoning and take out the acetylene nut and nipple ( CGA 510 ) and buy an inert Nut and nipple ( CGA 580 ) They take the Same Nipple which is a Western Enterprise or Superior # 15-3. The nut is different and both use 1/4 pipe threads..Set it at 2 PSI and it would work. Is it the correct way? Not at all. Will it work ? Yes. You can not convert PSI to CFH so turn it down until you get porassity in your weld... Then turn it back up until you dont. Then leave it alone. ( Should you do it? no. Would it work? Certainly..)
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
