mig gas usage ??
/ mig gas usage ?? #11
Terry, why limit yourself when you can dream of a rich nympho with a chain of liquor stores? :D
/ mig gas usage ?? #12
It's called 'attainable goals', Steve. Small steps.......
Terry
/ mig gas usage ?? #13
What style of flow meter are you using? is it the style that looks like a pressure gauge? or is it an actual flow meter with the glass tube and metal ball inside?
I dont like the style that looks like a gauge.
Ditto on getting a pressure gauge.
Also, are you opening the valve at the tank all the way? you are supposed to. Most of the valves have a double seat, meaning it seals the packing when fully opened. If you only open a little way, it can leak around the valve stem.
/ mig gas usage ?? #14
I was taught this way as well (in the 80's) but found out it is no longer necessary on high pressure valves/tanks and hasn't been for years.
(I hate it when I'm taught the right way and then it changes...)
Here is a link to a thread I started on the topic:
High pressure tank valves with o-rings
/ mig gas usage ?? #15
Interesting... thanks Dave.
I too was taught to open oxygen all of the way and acelylene only about a turn... and that wasn't all that long ago relative to some guys here (graduated hs in '02)
/ mig gas usage ?? #16
Yes, interesting. I'll still open mine all the way though. Except the Acetylene.
/ mig gas usage ?? #17
/ mig gas usage ??
Update : Full weekend of welding on son's new flatbed,, with new flow and pressure gauge.. Set for 15 liters and a full tank that read 2200 to start. We put 1.5 spools of wire through it and the pressure is down to 1800,, More like it :)
I think the old flow gauge was way off and that was the problem.. Thanks for all the input...
/ mig gas usage ?? #19
Good to hear, won't take long for that gauge to pay for itself now...
/ mig gas usage ?? #20
Hr3, you should go back to the first page and re-read my post - if you are REALLY using 15 LITERS PER MINUTE, then you are at 31.78 SCFH, which is about DOUBLE what you need.
Conversion Tools
Much higher, and you will be CAUSING problems with your welds instead of PREVENTING them... Steve
Sorry about the "shouting", but I hate to see someone paying twice as much as necessary :eek:
MMS 90B Hand Held Trowel (A60463)
MMS 90B Hand Held...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
14C SCRAPER (A58214)
2020 FORD F-550 CAB AND CHASSIS (A60736)
2020 FORD F-550...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
