Middle Buster & Subsoiler
   / Middle Buster & Subsoiler #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
What are they and when do you use them? Instead of a plow? In addition to a plow?
   / Middle Buster & Subsoiler #2
Mike-
For breaking up hardpan, and, with optional furrowing shovel, for making small ditches. I've also used one for cutting tree roots prior to removing stumps with FEL, and for preparing planting holes for trees. Very handy.
<font color=green>stan</font color=green>
   / Middle Buster & Subsoiler #3
OK
Now I am interested.
But what do they look like??
<font color=blue>Neil from OZ.</font color=blue>
   / Middle Buster & Subsoiler #4
Here is a picture of a middle buster
   / Middle Buster & Subsoiler #5
Here is a pictue of a subsoiler
   / Middle Buster & Subsoiler #6
And here is a picture that WVBill posted using his middle buster to make a trench.
Both can be purchased at TSC, Northern ect.
Hope that helps...
Paul
   / Middle Buster & Subsoiler #7
Aha
Sort of like my ripper with pipe layer. Except mine can dig a bit deeper. Sounds like the subsoiler. Refer photo.
The wide blade would never get thru my hard ground.
Cheers
   / Middle Buster & Subsoiler #8
Neil, a subsoiler normally is longer overall length than a middle buster, so it'll go deeper, and the blade is angled farther, although there are a few "combinations" on the market on which you just change the blade. I have the middle buster (great for digging potatos), and sometimes change the blade to a single heavy duty chisel plow blade, to dig narrow trenches.
Bird
   / Middle Buster & Subsoiler #9
MikePA,
I would suggest that you get the implement that Bird describes. It allows you to switch between the Middlebuster and Subsoiler. I wish I had.
I have used mine to create furrow for planting potatoes and then for havesting (pops those spuds out just real fine!!), trenched around my property to bury a hidden dog fence, trenched a friend property to bury electric line. Will be using it to trench to replant some hazelnut shrubs and rhubarb plants.
A good tool for the money.
Terry
<font color=blue>trenched a friend property to bury electric line</font color=blue>
How deep can you get with the implement?
TMA (A49461)
TMA (A49461)
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
UNUSED INDUSTRIAS AMERICA SK72 72" HYD BRUSH CUTTE (A51247)
UNUSED INDUSTRIAS...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
