Mid PTO switch
/ Mid PTO switch #1
dutchman56
Bronze Member
Northern Ontario
L4630GSTC
My mid PTO light is staying on and tractor will not start, GL4630GSTC. Were is the Switch and how to fix or jump.
/ Mid PTO switch
It turned out that the 5amp mini fuse in the fuse panel by the steering column labeled Key Stop was blown. Changed it and everything is fine.
What happen to make this blow is unknown. Using front mount blower and hit a rock. Turned off Rear and Mid PTO. Put everything in neutral. Stood up and tractor shut off. Tried to start but no crack and Mid PTO Light on.
Anyways got it running and hope this helps others.
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
1998 Polaris 4Wheeler (A66408)
1998 Polaris...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
