Mid PTO.dealer or factory
   / Mid PTO.dealer or factory #1
Theof
JD 1025TLB
On a 2021 L6060 with cab can dealer install mid PTO or does it have to come from factory.
   / Mid PTO.dealer or factory #2
Mid PTO can be installed by dealer on cab model L6060 tractors without split.
Not so of ROPS models.
SDT
   / Mid PTO.dealer or factory #3
I did my Mid PTO install on my L5240 cab earlier this year and it was not hard. I used the opportunity to change the hydraulic fluid a bit early and the filters since you have to drain it. It was nothing patticularly hard to do. Toughest part was getting off the cover plate (RTV and no places to pry) and then finding the dang connector for the microswitch that they buried up under the seat. Had to pull the seal and pan to find it.
   / Mid PTO.dealer or factory #4
That is interesting -- I never saw a mid PTO on that large a tractor. Just assumed you could not get them above some size/model. With the L6060 being strictly HST without any stick trans offered I guess that all fits. Would be a good model for a 72" MMM for those who do a lot of that work.
   / Mid PTO.dealer or factory #5
My build thread is still ongoing, but the Mid PTO stuff was completed a while ago. If you want to slog through the thread to see it, here it is...
   / Mid PTO.dealer or factory #6
on a tractor that size it is more likely used for front mounted attachments.
I bought my tractor used and the seller had already swapped out the mid pto from my tractor L4740 to his new L6060 so the mid pto parts even interchange between the 40 and 60 series.
I don't have any front attachments that require PTO power so I don't need the mid PTO.
   / Mid PTO.dealer or factory #7
now hurry up and get rid of that pint sized green machine and get a real tractor :)
   / Mid PTO.dealer or factory #8
Yes, particularily snow blower and rotary broom.
That said, a 72" MMM is available for the GL series.
SDT
  • Good Post
Reactions: JWR
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
SHOULE RM8080 LOT IDENTIFIER 116 (A53084)
SHOULE RM8080 LOT...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2020 RoGator RG1300C Spreader (A53342)
2020 RoGator...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
ITEM LOCATION LOT IDENTIFIER 3 (A53084)
ITEM LOCATION LOT...
