Mowing Mid Mower and Rear PTO
   / Mid Mower and Rear PTO #1
Alberta Boy
Hi all! First time question although I have been reading a lot of your advice the last 2 years. I have a New Holland TZ25DA. Sometimes I have a tiller attached to the back as well as the mower in the middle. When I lower the mower to cut grass, the 3pt in the back also lowers. Is there a way to lower only the middle mower and not the back tiller attached to the 3p hitch? Even if I disconnect the tiller, the 3pt in the back still moves up and down with the mower. Is this normal? It seems that they should be seperate so you can leave your rear tiller on while still cutting the grass.
   / Mid Mower and Rear PTO #2
Unless you tie the 3pt up, I don't know of a way to make them separate like you want.
   / Mid Mower and Rear PTO #3
My JD has a "kit" that holds up the 3PH for that reason-basically short chains and turnbuckles.
   / Mid Mower and Rear PTO #4
Assuming your TZ is the same or similar setup to the TC, your 3PH is what actually lifts your MMM. On my TC-24 you can pin the MMM in the up position to use the 3PH, but not the other way around. To raise or lower the mower, the 3PH arms have to move.
Brad
   / Mid Mower and Rear PTO #5
You can keep the mower up while you use the tiller but you cannot keep the rear up while you drop the mower.
Thanks for your input guys. Always nice to confirm the things that happen to you also happen to others and not always just because I don't know what the heck I'm doing.
Seems strange though that it will work one way and not the other.
Now I have to unload my tiller everytime I want to mow the lawn. Dang it!
   / Mid Mower and Rear PTO #7
Why would you want all that weight on there while mowing anyway? Just get a Quick-Hitch and then taking the tiller off will be easy;)
If you have one of these what?
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
Ford 8340 (A53317)
Ford 8340 (A53317)
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
