Mid Mount Mowers on B7800/B2910/B2920
   / Mid Mount Mowers on B7800/B2910/B2920 #1
davatk
Flint Hill, Virginia
Kubota B2630
New guy here.. :)
Does anyone know if RCK60-27B mid-mount mower (for the B7800, B2910 ) fit on a B2920 ? The B2920 docs call for a RCK60-29B, but the prior 2910 model used the 27B, and I thought (hope) they might be cross compatible.
Anyone know the answer to this ?
Thanks in advance,
Dave Atkins
   / Mid Mount Mowers on B7800/B2910/B2920 #2
David,
If your dealer has a good parts guy ... he should be able to tell you the difference. KennyV
PS . I see this is your first post, welcome aboard... come back often.
   / Mid Mount Mowers on B7800/B2910/B2920 #3
David,
I don't know the answer to your question, but I have a 2920 with MMM. The MMM is currently off the mower. If you need pictures or measurements, you can email me. The 2920 mower attaches to the front of the tractor with a bracket that can be seen in the top picture on the Kubota website in the B2920 implement picture. The back of the mower attaches with the linkage that drops down in the bottom picture to the bracket that sticks up shown in the next to the last picture. There are one of these on each side.
http://www.kubota.com/f/products/B20/pdf/b_series_others.pdf
   / Mid Mount Mowers on B7800/B2910/B2920 #4
The mmm for the B2920 is a suspended deck that mounts differently than the ground riding decks that go on the larger B series tractors. I doubt they will interchange without more work than it is worth.
4"x6" Cast Centrifugal Pump (A50121)
4"x6" Cast...
Skid steer auger plate (A50322)
Skid steer auger...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2011 Dodge Ram 3500HD (A50120)
2011 Dodge Ram...
