Mowing Mid Mount Mower too High. How do I adjust?
   / Mid Mount Mower too High. How do I adjust? #21
That's great news! Hope everything is OK! I really don't like how sloppy the lines are on these. I wish the backhoe had the length of lines and they plugged into a manifold somehow-similar to how the loader does.
I always feel like I'm either bending the hoses too much and putting tension on the fittings or I'm routing them wrong and they're gonna get severed.
   / Mid Mount Mower too High. How do I adjust? #22
I just bought a GC1723 with the drive over mid mount mower. I love the tractor but the mid mount mower wont go low enough. Right now at its lowest setting it is still cutting the grass 8 inches high. I have adjusted the cut height knob to no avail. Any ideas?
One question was your GC1723 cutting grass 8 high or was that just a measurement to the blades?
Can it actually cut grass and leave grass 8 tall?
My reason for asking is if it can curt grass 8 high it would be great for cutting by the fence in pastures.
   / Mid Mount Mower too High. How do I adjust? #23
Sure -- I use mine frequently as a poor man's bush hog. Just raise it all the way up and go through the brush. Not sure if it's 8" high, but probably close.
Country350 -- thanks for the update. I've had to play with my hoses in the back -- had the same thing happen to me-- which is why I suggested checking them for 3PH arm movement restriction.
   / Mid Mount Mower too High. How do I adjust? #24
I know that tractor data listed the cutting height for the GC1705/15s as 1” to 4.7” or4.9”, so 8” is a big jump.
Could someone measure it and see?
Another question is are the u-joints binding at that height on the mid-mount mower?
   / Mid Mount Mower too High. How do I adjust? #25
Sorry, still have my snow blower attached... though I THINK we're done with snow for this year :scratchchin:.... When I switch around, I'll check.
   / Mid Mount Mower too High. How do I adjust? #26
OK, made the switch today, figuring that we're probably safe from snow now.
Measured at full "UP" height, I get 6-1/2" between the cutting edge of the blades and the ground. Keep in mind, however, that this is on a "old" GC2310 with the 2325 MMM. Might be quite different than the new drive-over decks.
   / Mid Mount Mower too High. How do I adjust? #27
Thanks Irving.
Have you ever tried cutting at that height?
Carey
   / Mid Mount Mower too High. How do I adjust? #28
5:14:2019.jpg...And maybe I spoke too soon... it's snowing here this morning, though it shouldn't amount to much and ought to melt off quickly-- at least that's my hope!
Yes, I have used the MMM at that height, mainly in rough brushy areas, like under my power line. Like I said, "a poor man's bush hog".... It works quite well to take out any small trees that are trying to get a foothold. Do that maybe once a year.
   / Mid Mount Mower too High. How do I adjust? #29
View attachment 604629...And maybe I spoke too soon... it's snowing here this morning, though it shouldn't amount to much and ought to melt off quickly-- at least that's my hope!
Thanks just wanted to make sure the mid-pto was not binding at that height.
2105 (A58376)
2105 (A58376)
2025 CFG Industrial MH12RX Mini Excavator (A56857)
2025 CFG...
2024 Yakta YXR610 Zero Turn Lawnmower (A57453)
2024 Yakta YXR610...
Rooster Weathervane (A55853)
Rooster...
11' Container W/Side Door and Window (A57149)
11' Container...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
