Mowing Mid Mount Mower too High. How do I adjust?
   / Mid Mount Mower too High. How do I adjust? #21
That's great news! Hope everything is OK! I really don't like how sloppy the lines are on these. I wish the backhoe had the length of lines and they plugged into a manifold somehow-similar to how the loader does.
I always feel like I'm either bending the hoses too much and putting tension on the fittings or I'm routing them wrong and they're gonna get severed.
   / Mid Mount Mower too High. How do I adjust? #22
I just bought a GC1723 with the drive over mid mount mower. I love the tractor but the mid mount mower wont go low enough. Right now at its lowest setting it is still cutting the grass 8 inches high. I have adjusted the cut height knob to no avail. Any ideas?
One question was your GC1723 cutting grass 8 high or was that just a measurement to the blades?
Can it actually cut grass and leave grass 8 tall?
My reason for asking is if it can curt grass 8 high it would be great for cutting by the fence in pastures.
   / Mid Mount Mower too High. How do I adjust? #23
Sure -- I use mine frequently as a poor man's bush hog. Just raise it all the way up and go through the brush. Not sure if it's 8" high, but probably close.
Country350 -- thanks for the update. I've had to play with my hoses in the back -- had the same thing happen to me-- which is why I suggested checking them for 3PH arm movement restriction.
   / Mid Mount Mower too High. How do I adjust? #24
I know that tractor data listed the cutting height for the GC1705/15s as 1” to 4.7” or4.9”, so 8” is a big jump.
Could someone measure it and see?
Another question is are the u-joints binding at that height on the mid-mount mower?
   / Mid Mount Mower too High. How do I adjust? #25
Sorry, still have my snow blower attached... though I THINK we're done with snow for this year :scratchchin:.... When I switch around, I'll check.
   / Mid Mount Mower too High. How do I adjust? #26
OK, made the switch today, figuring that we're probably safe from snow now.
Measured at full "UP" height, I get 6-1/2" between the cutting edge of the blades and the ground. Keep in mind, however, that this is on a "old" GC2310 with the 2325 MMM. Might be quite different than the new drive-over decks.
   / Mid Mount Mower too High. How do I adjust? #27
Thanks Irving.
Have you ever tried cutting at that height?
Carey
   / Mid Mount Mower too High. How do I adjust? #28
5:14:2019.jpg...And maybe I spoke too soon... it's snowing here this morning, though it shouldn't amount to much and ought to melt off quickly-- at least that's my hope!
Yes, I have used the MMM at that height, mainly in rough brushy areas, like under my power line. Like I said, "a poor man's bush hog".... It works quite well to take out any small trees that are trying to get a foothold. Do that maybe once a year.
   / Mid Mount Mower too High. How do I adjust? #29
View attachment 604629...And maybe I spoke too soon... it's snowing here this morning, though it shouldn't amount to much and ought to melt off quickly-- at least that's my hope!
Thanks just wanted to make sure the mid-pto was not binding at that height.
2020 Takeuchi TB235-2 (A55272)
2020 Takeuchi...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
1994 EZ-GO Golf Cart (A56859)
1994 EZ-GO Golf...
105" - 3 CU YARD PIN ON LOADER BUCKET (A52708)
105" - 3 CU YARD...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
Mini-Skid Steer Vibratory Roller (New/Unused) (A59225)
Mini-Skid Steer...
