Mowing Mid Mount Mower Problems
/ Mid Mount Mower Problems #1
DaleW
Lower Hudson Valley New York
B2710 FEL with a 72 inch mid mount mower and teltrax canopy
Ran into a problem the other day while my son was mowing the field. Said he heard a snap and then the mower would not raise and the connecting rod was bent up and dragging on the ground. As you can see from the attachment, the connecting rod pulled through the mower lift arm bracket (Note the size of the connecting pin). Ordered a new bracket and connecting rod from Modern Equipment in Tenn. and had them in 2 days. What caused this was the connecting rods were too tight and the mower was topping out on the stops and causing undue stress and wear on the on the lift arm and connecting pin.
For those of you that have the 72" mid mount mower it is very important to check and adjust the mower per the manual so as not to wind up with this situation.
Hope this helps someone.
Keep on tractoring
Dale
/ Mid Mount Mower Problems #2
Thanks for the warning. I'm going to go check mine right now.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
3142 (A63117)
3142 (A63117)
1980 FRUEHAUF 45' T/A FLATBED TRAILER (A59911)
1980 FRUEHAUF 45'...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
2025 Kivel Quick...
JOHN DEERE 94520R ARTICULATING TRACTOR (A64280)
JOHN DEERE 94520R...
