Mowing Mid Mount Mower Problems
/ Mid Mount Mower Problems #1
DaleW
Lower Hudson Valley New York
B2710 FEL with a 72 inch mid mount mower and teltrax canopy
Ran into a problem the other day while my son was mowing the field. Said he heard a snap and then the mower would not raise and the connecting rod was bent up and dragging on the ground. As you can see from the attachment, the connecting rod pulled through the mower lift arm bracket (Note the size of the connecting pin). Ordered a new bracket and connecting rod from Modern Equipment in Tenn. and had them in 2 days. What caused this was the connecting rods were too tight and the mower was topping out on the stops and causing undue stress and wear on the on the lift arm and connecting pin.
For those of you that have the 72" mid mount mower it is very important to check and adjust the mower per the manual so as not to wind up with this situation.
Hope this helps someone.
Keep on tractoring
Dale
/ Mid Mount Mower Problems #2
Thanks for the warning. I'm going to go check mine right now.
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A64276)
2020 FORD F-150 XL...
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
