Mid mount lift on BX23 issue.
   / Mid mount lift on BX23 issue. #11
Fixed it. It was jammed against the bottom of the tractor. Fiddled with it long enough that it will lower properly.
Very good ! I suspected that would be the case. I was stymied on ours, took it to a shop and basically all they did was unjam it and do extra lube. In my case at least it had NOT been on rough terrain. Those suspension MMM take a beating bouncing around when the ground is rough even though the wheels are only intermittently touching. And somehow ours got jammed in the "up" position. I think this is probably not all that rare.
In my case, I wasn't on rough terrain. I was cutting the grass on a runoff that feeds into a pond. Smooth ground, and a gentle slope. However, it was the only still soft part of my field, and I got it stuck. I'm certain the damage came from tugging it out. I was delighted when it popped loose. I use that thing a lot.
  • Good Post
Reactions: JWR
   / Mid mount lift on BX23 issue. #13
Our 60” mmm was not coming up correctly. Removed mower deck and found shaft sleeve not lubricated. On my ZD331 ZTR the shaft coming down to mower deck has a grease fitting. Not so on the mmm of a BX2660 series.
   / Mid mount lift on BX23 issue. #14
even though the issue is now resolved, I would remove the deck and give it a good cleaning to get rid of mud, dirt, grass etc. then re-install everything.
When I had if off, I cleaned and lubed everything.
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
UNUSED FUTURE 24" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 24"...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
378811 (A51573)
378811 (A51573)
