Mice
coachgrd
nw PA
Kubota BX1870
I have a mice problem out in my shed where my JD 455 lives. I probably fire her up 4-5 times/week, even if to just give my little guys a ride. I'm noticing it sure doesn't take a mouse long to build a home in the engine compartment...a day or two and they move on in. /forums/images/graemlins/mad.gif Do you guys have a solution for this? I've tried finding and sealing up any holes in the shed. I think I could trap them from now until the cows come home. I can't be the only one with this problem.
Want a cat, I have several that I will loan you till the cows come home, or they go to the great cat box in the heavens
Set up mouse traps that kill mice. Peanut butter on them works great. You will need to empty then on a daily basis till the supply of mice runs out.
You might try putting some mothballs under and around your tractor. It worked for me, keeping them out of my old truck.
I use "RoPax"...little green balls that contain massive amounts of Vitamin K...rodents eat the balls and go away and die...hardly ever find a dead one...now I rarely see a live one, and they used to be thicker than maggots around the quail pens/feed room...
I get it at the local Co-Op...doesn't seem to bother any of the other critters either! /forums/images/graemlins/smile.gif
GareyD
We were having mice getting in the shop and house everytime we left the door open more than a couple minutes. I swear they would sit there and wait. The traps would catch them most of the the time pretty quick. Some I chased out and others got stomped on.
Then one day this super friendly cat showed up. Turns out he is quite the hunter. Rabbits, birds, pheasant, mice and bones/feet of what looks alike a turkey. Anyway NO mice since He's been around. Goooood Kitty!!!!!
I bought some bait/poison from TSC with a "petproof" enclosure. I leave it in my feedroom and haven't seen many mice in the grain bags. It seems to work well.
</font><font color="blue" class="small">( I have to agree with the cat. It solved my problem. )</font> My cat is the problem. She keeps bringing things into the house to play with. So far I've rescued and released a blue tailed skink, a chipmunk, 2 baby bunnys, 2 cardinals, a sparrow, and a dozen or so mice.
Dryer sheets? How many and where do you put them? /forums/images/graemlins/confused.gif
Hmmm. I believe you're mistaken here.
The mfg. label for Ropax states that the active ingredient is "Brodifacoum: 3-[3-(4'-bromo-[1,1'-biphenyl]-4-yl)-1,2,3,4-tetrahydro-1-naphthalenyl]-4-hydroxy-2H-1-benzopyran-2-one".
It goes on further to say, "If poisoning occurs, intramuscular and oral administration of vitamin K1 are indicated, as in poisoning from overdose of bishydroxy coumarin. For human cases, vitamin K1 is antidotal at doses of 10 to 20 mg (not mg/kg). "
Basically reading the label it appears this stuff isn't quite as "friendly" as you were led to believe.
Click on Manufacturer/Label Information for more detail.
I've been dealing with this for years. Finally found the best solution. Go to Home Depot and buy some DeCon, or order some mice poison from this site .
But keep pets away from it! Do you have any pets that might get into it?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 HINO 338 4X2 22FT CDL REQUIRED BOX TRUCK (A59909)
2018 HINO 338 4X2...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2019 FORD F-250 4X2 PICK UP TRUCK (A59908)
2019 FORD F-250...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
