Mice in my Kioti
   / Mice in my Kioti #11
One caution with poison is that the mice wander off to die and can be eaten by owls and other predators that are in turn killed.
   / Mice in my Kioti #12
I use cotton balls soaked in pure peppermint oil. Mice HATE peppermint oil and will avoid the smell at all costs. (It has to be pure peppermint oil.) I put a few balls in the engine compartment of each tractor, and in the cab of the Kioti and under the seat of the Kubota.
I also use a battery powered rodent repeller under the hood of each tractor and in the cab of my Kioti.
The combination of the peppermint oil and the electronic repellers has worked so far. I started using this method when I found a mouse had built a nest on top of the fuel tank (near the filler neck) of my Kioti.
   / Mice in my Kioti #13
I park my tractors & trucks on 3/4 inch road base and just spread some diesel underneath. The diesel soaks in but continues to 'reek'. If parking on a surface that you want to stay 'un-blemished' then pour some diesel into a pan or open-top can and pour in some diesel and set it underneath. Cotton balls or the like (Q-tips) doused with diesel will keep the little varmints out of cabs, etc. BUT you gotta be able to accept the smell yourself! :laughing:
   / Mice in my Kioti #14
   / Mice in my Kioti #15
Couple barn cats
   / Mice in my Kioti #16
Cinnamon sticks from Hobby Lobby also work and smell good. :thumbsup:
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
