Traction MFWD-Does it lock rear diff?
/ MFWD-Does it lock rear diff? #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
Does the design of the MFWD engagement also lock the rear diff? Or must you use the foot operated diff lock pedal at same time to get 4 driven wheels?
/ MFWD-Does it lock rear diff? #2
The engagement of the differential lock is separate from the mfwd engagement. With good reason, when the differential lock is engaged steering is dramatically reduced as the rear wheels want to go in a straight line.
That is what I thought. When trying to pull up a stump with chains, I am almost positive I have seen both rear wheels spinning w/o depressing the diff lock pedal. Is that possible? I would think not as I assume the rear diff is "open" and powers the wheel with least traction. But I am not sure. How is power determined to go to a rear wheel w/o diff lock engaged? Also, both front wheels are driven with MFWD engaged? Correct?
Perhaps the rear diff is mechanical limited slip?
/ MFWD-Does it lock rear diff? #5
It is easily possible that both rear wheels can spin without them being locked by the differential lock. If tractive forces, are equal both rear wheels will spin. Study how an open differential works, and it will answer your questions. One of the best ways to help with this is an old GM instructional video.
/ MFWD-Does it lock rear diff? #6
Not likely. You do not have to have Limited slip. If tractive forces are equal an open differential will pull equally.
/ MFWD-Does it lock rear diff? #7
Both will have power as long as both get traction. When one breaks free, then the other one will spin twice as fast. Some control by braking the one side that spins will get more traction. That is good use of the steering brakes. Can't do that on those hst tractors that have the individual steering brakes on the same side as the forward reverse pedals.
Answered well by previous post.
/ MFWD-Does it lock rear diff? #8
When one wheel breaks free it spins, not the opposite wheel.
/ MFWD-Does it lock rear diff? #9
Correct.. my bad.. should have said "breaks free and spins twice as fast"
/ MFWD-Does it lock rear diff? #10
Some of the larger tractors have a limited slip in the front axle. The rear axle is full lock or unlocked with the foot pedal usually. My Deere has limited slip in the front axle and differential lock in the rear, my kubota has an open diff in the front and a diff lock in the rear. Both have to be manually put in 4wd.
/ MFWD-Does it lock rear diff? #12
,,, ... And even more easily possible with AGs. -- Due to the action of the angled tread jamming the soil as it slips, a forward going AG will exhibit a little more pull as it slips. Thus one side with slightly less traction could slip a little causing its traction to increase enuf to make the other tire slip. When theyre close you can observe each tires spin to stop - start in little jerks as their traction advantage shifts back and forth.
/ MFWD-Does it lock rear diff? #13
,,, ... And even more easily possible with AGs. -- Due to the action of the angled tread jamming the soil as it slips a forward going AG will exhibit a little more pull as it slips. Thus one side with slightly less traction could slip a little causing its traction to increase enuf to make the other tire slip. When theyre close you can observe each tires spin to stop - start in little jerks as their traction advantage shifts back and forth.
True, and if one side takes off and starts to spin you can slow it down with your split brake and cause the differential action to put more force on to the opposite tire with better "hook up" to the ground to get you going forward again. Just a little single braking action on the wheel with lower traction will often make the difference.
/ MFWD-Does it lock rear diff? #14
My Massey Ferguson does the opposite. If you lock the rear differential it will automatically engage MFWD.
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2019 FREIGHTLINER CASCADIA 125 DAY CAB (A67714)
2019 FREIGHTLINER...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Hyundai GP Bucket (A68134)
Hyundai GP Bucket...
