MF54 Backhoe Pivot cylinder
   / MF54 Backhoe Pivot cylinder #1
Franklin1359
morganton,nc
MF54
Hello everyone
I am working on a MF54 backhoe pivot cylinder. The problem I am having is finding the check valves(AKA stop valves)both left and right. I do not know if they are the same. I called a couple of MF dealers parts department and they say parts for that model has been discontinued. Does anyone know some resources to get parts for the MF54.
thanks
   / MF54 Backhoe Pivot cylinder #2
:welcome:
To the TBN forum Franklin. Someone on here should be able to help you.
   / MF54 Backhoe Pivot cylinder #3
is that a "rotary cylinder" as they call it, or your typical push-pull ram type setup?
yes it is also referred to as a rotary cylinder and tubular stops ar also call spool stops there are 2 of them one for the left and one for the right.
   / MF54 Backhoe Pivot cylinder #5
Agco Parts shows the spool stops as Part # 1031694M1. I cant find ANYTHING available online. The parts diagram looks like the stops would be pretty simple lathe work, you might consider having 2 new ones machined.
yes i agree with part number and have not found any on line. will look in the having it made. thanks
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
2023 JACTO ARBUS-1000 LOT IDENTIFIER 68 (A53084)
2023 JACTO...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
