MF54 Backhoe Pivot cylinder
   / MF54 Backhoe Pivot cylinder #1
Franklin1359
morganton,nc
MF54
Hello everyone
I am working on a MF54 backhoe pivot cylinder. The problem I am having is finding the check valves(AKA stop valves)both left and right. I do not know if they are the same. I called a couple of MF dealers parts department and they say parts for that model has been discontinued. Does anyone know some resources to get parts for the MF54.
thanks
   / MF54 Backhoe Pivot cylinder #2
:welcome:
To the TBN forum Franklin. Someone on here should be able to help you.
   / MF54 Backhoe Pivot cylinder #3
is that a "rotary cylinder" as they call it, or your typical push-pull ram type setup?
yes it is also referred to as a rotary cylinder and tubular stops ar also call spool stops there are 2 of them one for the left and one for the right.
   / MF54 Backhoe Pivot cylinder #5
Agco Parts shows the spool stops as Part # 1031694M1. I cant find ANYTHING available online. The parts diagram looks like the stops would be pretty simple lathe work, you might consider having 2 new ones machined.
yes i agree with part number and have not found any on line. will look in the having it made. thanks
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
UNUSED INDUSTRIAS AMERICA F08 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
378812 (A51573)
378812 (A51573)
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
