MF400C Drott/Dozer or Hanomag
/ MF400C Drott/Dozer or Hanomag #1
OCF
Brisbane, Queensland
MF400C
Hi All,
Having a great deal of difficultly finding information on this MF400C which I have owned for about a year. The final drive seals were shot and subsequently let water and dirt into the final drive compartment, so I removed the sprocket etc to replace the seals. I noticed on the outside bull gear bearing there was slight pitting and hard face wear/removal. So I am wanting to replace all the bearing's etc in the final drive. Availability is no issue, but I can't find the correct bearing pre-load anywhere. All these bearings are shimmed and if I can't find the right pre-load information, I have half tempted to put the old bearings back in. Any information would be appreciated? Cheers OCF
/ MF400C Drott/Dozer or Hanomag #2
Thanks fella's. I checked out the links, but they seem to be for a wheeled MF Tractor. Mine is a MF400C Drott. I will keep researching and hopefully something will jump out at me. Appreciate your help and efforts mate. Cheers OCF
Landhonor 3Pt Stump Grinder (A66408)
Landhonor 3Pt...
2023 General XP 1000 Sport (A62679)
2023 General XP...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
(1) 30 Yard Roll Off Dumpster and (1) 20 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
