mf40 ind with mf32 loader
/ mf40 ind with mf32 loader #1
mellowrose
hallettsville tx
ford 1900 kubota b8200 ford 1700 all 4 wheel drive
the loader was leaking a little around the tilt cylinders. so we changed the seals and filter on the system. put some hyd fluid in and started it up. no up and down or tilt on the loader. this is odd because it was working before, except leaking. I have not done a lot of seal changes on cylinders, but it is pretty straight forward. not really familiar with this model but I do have a ford 1900 and a Kubota b8200. I have done the ford cylinders without a problem. I think I am missing something. any ideas would be appreciated.
/ mf40 ind with mf32 loader #2
You probably still have some air in the lines.
Cycle the cyl to full extend and retract about 10 times , or more.
well that's what I thought, so I let the motor run and kept working the valve. one of the up and down cylinders moves about an inch and as soon as nit hits resistance it stops. so I would do what you said but the cylinders wont extend. none of them.
/ mf40 ind with mf32 loader #4
Do you have any QD's on the hoses?
If so, reset them.
no qd's but I am beginning to think there is a leak somewhere. I read where the rubber hose that connects the 2 pipes in the suction line, can suck air but not leak fluid. the one on this tractor looks like it could do that. I need a flow diagram I guess.
well I disconnected the tilt cylinders at the bucket and they go in and nout but there is no pressure because I can hold them in. I let go and they go in and out. next step is with a pressure gauge , when I get one.
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
(10) New CATERPILLAR Keys (A65579)
(10) New...
