MF35 tempreture gauge
   / MF35 tempreture gauge #1
M
mattrow
Guest
Hi. From the serial numbers and codes I am almost certain that my tractor is 1962 MF35 with the three cylinder Diesel engine 3-A-152 Diesel. I have just replaced the water pump and of concern is that the tractor did not come with a temperature gauge. It had an oil and volt gauge but no temp. gauge. Having looked around a bit I am coming to the conclusion that the MF35 did come with a temp. gauge but not on the 3 cylinder Diesel model. Is this correct.? Was there a reason? Can I put one on now? And if so where (Exactly) is the plug hole that I would install it.? Thanks for your time and info.
   / MF35 tempreture gauge #2
Is it a special or a deluxe?
Not sure the metal tag says it is an FE35. But the seriel number is SNM 28672 which says it is a 1962 MF35. So sorry not sure if a special or not.
Hi reading other posts it has a 2 stage clutch which I think makes it a deluxe.
   / MF35 tempreture gauge #5
If it's a Deluxe. The water temp gauge goes in the upper right hole. The water temp gauge screws in at the thermostat housing I believe. You should have four gauges with the Tach in the middle. I would think a temp gauge is a must have on a tractor. One could do without a amp/volt gauge. If you gauge is indeed a VOLT instead of AMP it has been replaced. Do you also have an alternator on it?
Goto: AGCO Parts Books login as QUEST and bring up your tractor to compare
Welcome to TractorByNet. :biggrin: . -kid
2019 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2019 JLG ECOLIFT...
(3) Telephone Poles (A50515)
(3) Telephone...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
KUBOTA M9000 TRACTOR (A51243)
KUBOTA M9000...
Best 30' Grain Drill (A50514)
Best 30' Grain...
IH 480 18' Disk (A50515)
IH 480 18' Disk...
