MF35 tempreture gauge
   / MF35 tempreture gauge #1
M
mattrow
Guest
Hi. From the serial numbers and codes I am almost certain that my tractor is 1962 MF35 with the three cylinder Diesel engine 3-A-152 Diesel. I have just replaced the water pump and of concern is that the tractor did not come with a temperature gauge. It had an oil and volt gauge but no temp. gauge. Having looked around a bit I am coming to the conclusion that the MF35 did come with a temp. gauge but not on the 3 cylinder Diesel model. Is this correct.? Was there a reason? Can I put one on now? And if so where (Exactly) is the plug hole that I would install it.? Thanks for your time and info.
   / MF35 tempreture gauge #2
Is it a special or a deluxe?
Not sure the metal tag says it is an FE35. But the seriel number is SNM 28672 which says it is a 1962 MF35. So sorry not sure if a special or not.
Hi reading other posts it has a 2 stage clutch which I think makes it a deluxe.
   / MF35 tempreture gauge #5
If it's a Deluxe. The water temp gauge goes in the upper right hole. The water temp gauge screws in at the thermostat housing I believe. You should have four gauges with the Tach in the middle. I would think a temp gauge is a must have on a tractor. One could do without a amp/volt gauge. If you gauge is indeed a VOLT instead of AMP it has been replaced. Do you also have an alternator on it?
Goto: AGCO Parts Books login as QUEST and bring up your tractor to compare
Welcome to TractorByNet. :biggrin: . -kid
Poly Round Bale Ring (A50515)
Poly Round Bale...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
(3) Hose Reels (1) Air (2) Oxygen and Acetylene (A47384)
(3) Hose Reels (1)...
2008 Ford F-250 4x4 Pickup Truck (A50323)
2008 Ford F-250...
2021 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
2021 CATERPILLAR...
