M
mattrow
Guest
Hi. From the serial numbers and codes I am almost certain that my tractor is 1962 MF35 with the three cylinder Diesel engine 3-A-152 Diesel. I have just replaced the water pump and of concern is that the tractor did not come with a temperature gauge. It had an oil and volt gauge but no temp. gauge. Having looked around a bit I am coming to the conclusion that the MF35 did come with a temp. gauge but not on the 3 cylinder Diesel model. Is this correct.? Was there a reason? Can I put one on now? And if so where (Exactly) is the plug hole that I would install it.? Thanks for your time and info.
