MF35 stuck in reverse
   / MF35 stuck in reverse #1
FrankT
MF35 stuck in reverse..shift will not move...been advised to push on fork (through transmission fill hole) with screw driver or small crow bar. What part fork & in what direction do I push? Does it takle much force? dont want to break anything
   / MF35 stuck in reverse #3
Frank, the link JerryG gave is a good one, and tells exacatly how to correct the problem. Mine got stuck several years ago, and I freed it up. I was also nervous about putting too much pressure on the gears and breaking something else.
It takes a good size screw driver, or pry bar. It also took some trial and error - it's hard to see in that little access hole. Finally out of desperation, I gave it a good shove, and the gear moved where it was supposed to be. Have never had the problem since.
Good luck, and let us know if you get it fixed.
   / MF35 stuck in reverse #4
I used to have that problem, but it stuck in first. I would open the fill hole and with a heavy screw driver slip the fork back. I can't remember the shift pattern, but if you move the stick forward to go to reverse, you will move the fork forward to take it out.
   / MF35 stuck in reverse #5
Frankt, did you get your transmission freed up?
Bob
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
Bryant 650AN048-E A/C Unit (A49462)
Bryant 650AN048-E...
1041 (A50459)
1041 (A50459)
Online Buyers Premium (A47384)
Online Buyers...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
2016 FREIGHTLINER 2500 SPRINTER VAN (A51222)
2016 FREIGHTLINER...
