Mf35 goes full throttle at startup after reseal of cav
   / Mf35 goes full throttle at startup after reseal of cav #11
Yes there is an oring on the shaft right below the “basket” it basically seals that area to the drive hub & locks the basket to the shaft when force is applied from the “tomb stone”..
There r 2 sizes of orings that go on the shaft depending on which wt cage u have..
It sounds like u have a single piece wt cage, so your oring is going to be thin..
I’m sure u saw the fat oring in the kit.?? THAT goes to the 2 piece wt cage that has 4 rubber buffers.. don’t use the fat oring..
I think u might be worried for nuthin.. your whole problem was the thrust washer position.. under the flyweights..
Now that u have both pieces sitting in the groove of the weights.. your good.
Your way ahead of the game than most.. at least you got yours to run..😝
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
NEW Thiessen Track Closer Disk (A55218)
NEW Thiessen Track...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
2019 RAM 2500 Crew Cab Pickup Truck (A55788)
2019 RAM 2500 Crew...
