MF35 Front Loader Hose Layout
/ MF35 Front Loader Hose Layout #1
congo181
Maidstone, Kent
Massey Ferguson 35, 1964
Can some kind owner with an older MF, ideally a 35 (but a 100 series would probably do), with a front loader on, please let me have some details of the hydraulic hose routing from the diverter valve to the loader cylinders?
Its the last part of my rebuild, and I cannot see how to route these hoses nicely, especially on the RHS past the exhaust pipe.
A few photos would be ideal of course :)
Many thanks in advance,
Jim
/ MF35 Front Loader Hose Layout #2
Hi Jim
Did you ever receive a response or successfully fit the hoses? I have just sourced a front loader for my MF35 and am in a similar position to you. It would be fantastic if you could help.
Kind regards
Dave
Hi Dave,
I didn't get any replies, but I have fitted the loader and hydraulics to my satisfaction and all is working well.
If you tell me exactly what your looking at, I'll take some pictures for you.
Jim
/ MF35 Front Loader Hose Layout #4
Hi Jim & Dave
I've got the same problem...
Is there any chance of some photos of the the routing of the pipes from the spool valves and the location and attachment for the ends where they connect to the loader pipes
Thanks
Caroline
Hi Caroline.
I have successfully fitted the hoses now and all works well.
I don't know if I have the pics with me - working away - but I will either post them soon or when I'm back.
Jim
/ MF35 Front Loader Hose Layout #6
Do this to figure out the FEL valve hose arrangment.
Remove work port hoses from the FEL valve.
Push lever fwd momentary. Fluid should come out one of the ports. That hose goes to the rod end of the lift cyl.
Pull lever back. That port fluid should go to the lift cyl base end.
Push lever left. That port will go to the bucket rod end.
Push lever right. That port goes to the bucket cyl base end.
/ MF35 Front Loader Hose Layout #7
Jim
Did you mean diverter valve or FEL valve?
/ MF35 Front Loader Hose Layout #8
Thanks Jim
Caroline
Sorry, but I cant find the pictures here but I can describe to you what I did if that will suffice. Its not very complex after all.
If you're not in too much of a hurry I can get the pictures and make some measurements for you next time I'm back home, but that wont be till beginning of October.
Let me know,
Jim
Caroline,
Here are the photos. I found them finally.
Any questions, please ask.
Jim
/ MF35 Front Loader Hose Layout #11
Thanks Jim, that great
Caroline
Caroline,
You're welcome.
I used a mixture of weld-on hose clamps, fabricated brackets and cable ties to hold it all down in the end. I would probably have made the radius of the bend at the loader arm different if I did it again.
Its OK in normal use but when the loader is removed the rams need to move more and this can bend the hoses at the base overly.
You will see that I put in a rear take-off from the second port of the diverter valve to a bracket at the rear by the original tipping trailer fitting. The return hose for this goes to a fitting tapped into the oil filler cap as shown.
I use this for my log splitter at the moment, and it works fine.
Let me know how you get on.
Jim
2023 Case TV380 (A62177)
2023 Case TV380...
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
John Deere 1025R (A62177)
John Deere 1025R...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
