MF35 Front Loader Hose Layout
/ MF35 Front Loader Hose Layout #11
Thanks Jim, that great
Caroline
Caroline,
You're welcome.
I used a mixture of weld-on hose clamps, fabricated brackets and cable ties to hold it all down in the end. I would probably have made the radius of the bend at the loader arm different if I did it again.
Its OK in normal use but when the loader is removed the rams need to move more and this can bend the hoses at the base overly.
You will see that I put in a rear take-off from the second port of the diverter valve to a bracket at the rear by the original tipping trailer fitting. The return hose for this goes to a fitting tapped into the oil filler cap as shown.
I use this for my log splitter at the moment, and it works fine.
Let me know how you get on.
Jim
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2008 Sea Ray 260 Boat w T/A Boat trailer (A59231)
2008 Sea Ray 260...
