MF30B Clutch Replacement
/ MF30B Clutch Replacement #1
Farris
MF30B
Hello all,
Farris here. First post so please bear with me...
I have a Massey Ferguson 30B loader tractor that needs a clutch. I've started splitting the tractor and my question is; can the loader be left on the tractor then split and roll the rear section back or will the loader have to come off? The tractor has a three point lift and PTO. No back hoe or roof. Also, will the entire dash/steering assembly have to be removed or can I leave the dash installed? Thanks in advance guys!
-farris
/ MF30B Clutch Replacement #2
If you have the 6x6 shuttle, or 8x2 transmission and a 32a or 34a loader you will most likely want to leave the loader attached to the front and roll it back from the rear. If you have a different loader it will most likely be easier to remove the loader. The dash can be left on the rear of the tractor, you will have to disconnect the steering lines and electrical. When rolling the rear back make sure the transmission is in neutral. If you have any questions let me know. I have a 20C, that is almost identical to the 30B (except the rear axle).
2017 Gravely ZT-X 52in Zero Turn Commercial Mower (A64194)
2017 Gravely ZT-X...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
UNVERFERTH 6R36" RIPPER / STRIPPER (A64278)
UNVERFERTH 6R36"...
2017 Ford F-550 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
2022 Timpte T/A Super Hopper Grain Trailer (A64194)
2022 Timpte T/A...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
