MF245 lift problem
/ MF245 lift problem #1
halwest
Severna Park, MD
Ferguson TO35, Massey Ferguson 245
I have a Massey Ferguson 245 orchard model, Perkins 3 cyl. diesel, power steering, dual remote hydraulics. Purchased used. First thing I did was change all fluids and filters. Recently the rear lift will only raise when the tractor is running at a low (less than 500 RPM) If RPMs are increased the lift arms will lower. As the engine warms up I am able to increase the RPM's and the lift will work. Once everything is fully warmed up it appears to work normally. Through all this the auxiliary hydraulics
work normally. If I shut off the engine with an implement (5' finish mower) in a raised position the implement will stay in the raised position. Based on the casting # on the lift cover, the system is not pressure controlled. I have both the service manual and the operator's manual and can find nothing on this specific problem. Any help / thoughts on this would be greatly appreciated.
OOPS!. Tractor may or may not be pressure controlled. Not sure how to check. Meant to say tractor does not have a dash pot.
/ MF245 lift problem #3
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
2021 YANMAR VIO35-6A EXCAVATOR (A63276)
2021 YANMAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
